fried ecu?!
while fixing the alternator connector, one of the wires kinda touched the alt body for like 1 sec before I take them apart
I think one of the fuses blew but all of them were still connected(there was a little smoke in the fuse box) now nothing works... what have I done ?
DIY FTW! 1993 SVX 25th Anniversary Edition @+142k -Rebuilt Tranny @135k -Regasketed Engine @140k -Enkei Raijin 18x8.5, with 255/35/18's @140k -BC racing Coilovers (From STI's) @142k |
Re: fried ecu?!
Check your fusible link. It is in the fuse box and looks like a thick piece of wire. They're about $5 new from Subaru.
Re: fried ecu?!
thank you very much
yeah that was it...it looked ok but when i took it out it came apart so the ecu is okay, right?
Re: fried ecu?!
Everything else SHOULD be okay if it tripped the fusible link. The only situations where anything else gets damaged is if there is an overvoltage/overcharging situation when the voltage regulator goes out in the alternator. This can lead to fried control modules and wiring, but in your situation, replace the link and you should be good to go.
Re: fried ecu?!
When doing any electrical work, always disconnect the battery first.
Re: fried ecu?!
82301GA060 Subaru current price is $10.02
Re: fried ecu?!
is there any substitute part i can get from autozone or other part stores?!
Re: fried ecu?!
Since electrical systems and ECUs, TCUs, wiring harnessed are kind of expencive, why not just use the right, proven, Subaru part?
Re: fried ecu?!
I couldn't find anything like this in part stores so I guess that leaves me with one option thank you guys...great help like always
Re: fried ecu?!
I went to napa showed them the old one bought same gauge wire and connectors and made 2 of them for about 5 bucks..................G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
Re: fried ecu?!
So FIFTY CENTS A YEAR is too much to keep your SVX running properly. http://www.youtube.com/watch?v=9x3M8310qzs
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 02-12-2012 at 05:41 PM. |
Re: fried ecu?!
Re: fried ecu?!
Do things right, or don't do them at all. |
Re: fried ecu?!
why do you guys have to tie everything with money and destroyed or burnt cars?! i strongly advise getting a legit part instead of a made up one because the link is supposed to have the high angle and that is what takes the wires apart when melted...if it was short and/or made out of a more flexible wire, it wouldn't have blown
Re: fried ecu?!
Be sure to order a couple, or find some in a local junkyard with Subies. Subaru used the same ones in just about every subie in the 90's, and maybe even newer as well. If you need one ASAP
