Old 02-17-2012, 10:57 PM
Re: Too much timing belt travel...
I am relieved to say that after over two weeks and 105 posts, the problem has been solved!
The culprit being a defective timing belt. I picked up the new OEM belt from subaru earlier today. Upon inspection and comparison the new belt and previous belt (PCI) looked essentially the same. The markings on the new belt from Subaru however were much more helpful. There was a dotted line across the belt which related to alignment with the crankshaft sprocket and timing marks, whereas the other two marks were solid lines for the right and left bank camshaft sprockets. Simple and easy no guess work involved.
I did notice that there was more slack on the new belt as opposed to the old. This was confirmed when I removed the allen wrench from the hydraulic tensioner, the piston extended sigificantly more than with the previous belt. Perhaps I had the wrong belt all along...I'll never know I guess.
I know others have used PCI for the timing belt kit and have installed without any problems. But like any mass produced product I unfortunately came upon a defective unit in the bunch.
Thanks again for everyone's help, I am greatly apprectiative. Hopefully my misfortune and the responding posts will benefit others in the future.
http://youtu.be/rHGZzcjjF2I
Old 02-18-2012, 12:00 AM
Edit: I apologize as I just finally was able to watch the video's. It seems the belt is shifting in the same spot every time. Inspect the belt when you have it removed. It may be a bad belt.
Visual inspection may not work either. Try putting your old belt on, if you still have it, without connecting any of the accessories (a/c, pwr steering, alternator) start the car and see if it does the same thing.
Glad you solved it.
Old 02-18-2012, 12:04 AM
10 characters
Green1995SVX's Avatar
Glad you solved it.
I'll translate this for those of you playing along at home.
"I told you so!"
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 02-18-2012, 12:31 AM
cthommes cthommes is offline
So... Have you checked the cam pulleys yet?
Old 02-18-2012, 06:57 AM
michael's Avatar
michael michael is offline
What Potholes ???
I called it back on post #66
Wanted: Steering Wheel
Old 02-18-2012, 08:30 AM
Was that before nate? Apparently it's a competition to see who solved it/called it first.
Old 02-18-2012, 10:21 AM
While I didn't post it first, I think I posted it the most.... Does that count for a consolation prize?
Old 02-18-2012, 05:50 PM
I'm more glad that you were finally able to get the problem solved.
It is probably a bigger relief to you knowing that you did everything properly, but a "damaged" part was causing the issue.
Old 02-18-2012, 05:58 PM
I suggested it was a bad belt almost 10 years ago because I can see into the future. Therefore, I win. Mods, you can close the thread now.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 02-18-2012, 08:58 PM
10 years, Pffff
In the begining Moog and I made cave painting about bad belt.
Still on wall by Mamoth carcass!
