Old 11-18-2011, 04:43 PM
subaru keys
i only have a crappy metal one for my new pearlie but would like to get an oem or "subaru key" i looked on ebay and there are a few different style ones , but will they all be able to be cut down to use or are some of them a different key design (groove lines in them )?
Old 11-18-2011, 05:17 PM
Re: subaru keys
There are at least two key types, which are close, but not quite the same. You can use the 90's style ones, but not the 2000s style ones, basically. There's not a great selection... May I recommend this? I have one and I like it a lot.
Old 11-18-2011, 07:23 PM
Re: subaru keys
oh ok , thanks icing they look good il probably get one of those , i liked the one from my first pearlie , im guessing it is the one that came with them stock
Old 11-18-2011, 09:26 PM
Green1995SVX's Avatar
Re: subaru keys
The 2000s style keys actually CAN be used with an SVX, they just need to be "shaved" down a bit.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 11-18-2011, 11:01 PM
Re: subaru keys
You mean shortened or made flatter?
Old 11-18-2011, 11:35 PM
Re: subaru keys
You need to make it flatter. They are longer, but it doesnt matter. The key just sticks out of the ignition lock a little bit more.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 11-20-2011, 06:35 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Re: subaru keys
My car came with two keys (actually four, but two of them don't go to it!). One was the "master" key with the black plastic head and the valet key had the dark brown/grayish color head. The only difference between the two is the grooves. I think the groove spacing is a little closer together on the valet key. I work at a hardware store and we copy keys, so I looked to see if we had a blank that would fit the SVX. None of the "subaru" blanks fit it, but I found a Nissan blank that works just fine. The grooves are the same as the master key. The only difference is the handle shape.
Old 11-20-2011, 06:55 PM
Re: subaru keys
What is the Key #. I work in hardware also.
Old 11-20-2011, 07:33 PM
Re: subaru keys
O? 1234567
Old 11-20-2011, 07:34 PM
Re: subaru keys
37R? I could be wrong though.
Old 11-20-2011, 08:29 PM
SVX8588's Avatar
Re: subaru keys
It's an Ilco key. It's says DA25-X123 on it.
http://www.doitbest.com/Key+blanks-I...sku-205737.dib
It's not surprising since our cars share a lot with Nissans, especially the Pathfinder.
Old 11-20-2011, 08:42 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: subaru keys
Don't get those! ^ they break, VERY easily. i had 2 of them and they both broke within a month. i have those generic walmart ones, and they haven't broken yet.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-20-2011, 10:31 PM
Re: subaru keys
I had one of those break off in the ignition of one of my previous svxs. It left me stranded at a gas station in Virginia while I waited for a locksmith to come out on a Sunday! That wasn't cheap.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 11-20-2011, 11:45 PM
dbarnblatt's Avatar
Re: subaru keys
Subaru SVX OEM Key - 57497KG020 - Around $9-$12/ea. I just bought 2 recently.
Old 11-21-2011, 09:32 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: subaru keys
Are you saying we can't use one of these? Because this was kinda my plan.
