Old 11-29-2010, 09:12 PM
Huskymaniac's Avatar
Uses the ignore feature
Grill technical aspects
Does the 1997/Euro/JDM grill improve air flow to the radiator? Has anyone done a before and after on operating temperatures?
On a related topic, that foam between the radiator and frame is deteriorating on my car. I want to remove it but I think it actually helps cooling. I think it prevents hot air from the engine cabin from being sucked in and passing through the radiator. I'm thinking of gluing or screwing in a flap of silicone in its place.
Tony
Old 11-29-2010, 09:38 PM
Re: Grill technical aspects
The 97 grille is for cosmetics only.
The engine temperatures do not change even without the grille.
The gasket is now gone, it had a good life.
Let it go...
Old 11-29-2010, 10:38 PM
Green1995SVX's Avatar
You can get stick-on foam at Home Depot that is almost a perfect match for the OEM foam gasket. I used the remaining bits to seal up my basement door!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 11-30-2010, 07:02 AM
Manarius's Avatar
Manarius Manarius is offline
Early to mid 1990's cars were very over engineered. The foam? Good idea but not necessary. Power steering cooler? Totally unnecessary.
The front openings of the car are large enough already, I change in maybe 20 square inches of grill space isn't going to effect cooling at all.
-Jason
-Obi Wan Kenobi
Old 11-30-2010, 07:29 AM
Oh... come on...
Old 11-30-2010, 07:35 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
*cough* transaxle *cough*
Old 11-30-2010, 04:03 PM
Manarius's Avatar
Originally Posted by SilverSpear View Post
Oh... come on...
Name another car that has one. Seriously! Not even the STI does.
-Jason
-Obi Wan Kenobi
Old 11-30-2010, 04:16 PM
nexus_7 nexus_7 is offline
my xterra has one.
Old 11-30-2010, 04:43 PM
Almost every truck/van has one from the mid 90s forward and so do many cars...
Old 11-30-2010, 05:51 PM
Several of my SVXi have the PS delete option...
As does YT's old car now owned by LetItSnow, also I believe that sickSubie has the delete option as well.
for myself it has been, 5-7 years?
What year is this now???
Old 11-30-2010, 07:38 PM
XT6Wagon XT6Wagon is offline
Some of the STi's do come with PS coolers. I think they started in 05 or 06. Its just fins on the pipe, but if you start getting agressive with the wheel (AutoX) or using it for long periods (track days, moutain roads), it helps alot.
As far as the radiator, I would replace the foam. If only to keep things from falling between the condensor and radiator.
The grill... you have to be careful. To keep proper flow, the inlet area must remain smaller than the exit area. So the openings to the radiator have to be smaller than the area of the radiator, and the openings from the engine bay have to be larger than that. Not a big issue for most street cars, but somepeople find issues when they start opening up huge holes in the front to "supply more air" and instead kill the flow across the radiator since it just forms a big pocket of stagnent air and the primary flow goes around.
Old 11-30-2010, 07:56 PM
Great points about the air flow. I can't help but wonder if the grill change in 1997 wasn't an engineering decision versus a design decision. The opening in the 1997 grill certainly wouldn't cause the inlet to exceed the exit area but it does look bigger than the older grill. I guess no one has ever replaced the old grill and done a before and after temperature test to see what the impact was, if anything. And, Tom, it isn't just coolant temperature which would drop but the tranny temp would drop as well. So long as you don't cause running temperatures to drop below the optimal temperature, cooler is always better. I would guess optimal is somewhere around 185-195 based on information that the tstat is fully open at 195F.
Tony
Old 11-30-2010, 08:53 PM
My s6 has one and my S8 has a GIANT one.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 12-01-2010, 06:07 AM
dcarrb dcarrb is offline
First thing that crossed my mind when I read "deteriorating foam" was, old radiator. Second thing was, be mindful that the top tank could crack soon. Or not.
My totally novice take on the grille is that it was the cheapest last-gasp cosmetic update Subaru could make to a dreadful marketing failure, and that operating temperature differences (1992-'96 vs. '97 vs. no grille at all) would be so inconsequential as to be impossible to measure outside a laboratory.
dcb
