Got the new temp sensor..still no start
Installed the new temp sensor, it works as far as I can tell. When I unplug the sensor with the ignition on, the fans turn on. This tells me the wiring to the ecu is good. Why will she not fire? Fuel pressure is good, timing belt looked good, cam marks lined up. ??????
"Madness, as you know, is a lot like gravity, all it takes is a little push. “ |
Re: Got the new temp sensor..still no start
Did you reset the ECU by pulling the negative battery terminal wire for at least 1/2 hour and then trying to start the car?
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
I did disconnect the battery for an hour. I only ran the self diagnostic, engine light gave a code 21 ( temp sensor). The engine cranks over just fine, sometimes it tries to fire on a cylinder or two, but never enough to actually start. Winter is almost here; I need her running before the snow hits, any suggestions? I believe this is the stock ECU.
"Madness, as you know, is a lot like gravity, all it takes is a little push. “ Last edited by JWillysvx; 12-01-2009 at 06:43 PM. |
If no new codes are shown, take the O2 sensors out and let them dangle. Try to start it again after some time has passed.
Still showing 21 after the new sensor install... is there another way to clear the codes?
Check this:Codes cleared! Still...no start
no more codes...I have spark, The injectors are pulsing , fuel to the fuel rail.......????
,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, So close, so close I can almost reach..............
<< no more codes...I have spark, The injectors are pulsing , fuel to the fuel rail.......???? >>
do you have spark on all 6 and how do you know?
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it. |
If you have verified spark AND fuel, then you have either an air metering problem, or a timing problem...or possibly even something weird like a clogged catalytic converter.
You did check all three timing points correct? The crank was TDC and you verified the cam NOTCHES matched the notches on the back timing cover? I cant remember if I asked before or not on another thread. |
no more codes...I have spark, The injectors are pulsing , fuel to the fuel rail.......????"
Took the cam covers off and crank pully. According to the diagram SoCalLS-L sent me, thanx for that. All marks were aligned properly, so now I will try some of the other suggestions here. I will take the 02 sensors out and let them "dangle" for a while.............. Snowed 6 inches in the past few days, looking forward to me and my SVX playing the snow!
"Madness, as you know, is a lot like gravity, all it takes is a little push. “ Last edited by JWillysvx; 12-07-2009 at 07:18 AM. |
My girlfriend said she put regular unleaded in the tank. What would this cause for problems?
Keith |
Wishful thinking on my part. I have worked on all my own vehicles since I had my first car, right now I am stumped!
I have checked everything I think could be wrong......or have I?
