Old 03-24-2009, 09:32 AM
Re: adjusting brake band - dealer told me
Originally Posted by oregondave View Post
I hear you but you still didn't explain why the POWER flush is a bad thing.
Lets say you have an automatic transmission with very small oil passages, and you have 120,000miles on it.
After years of 200° temps. jack jabbit starts, sitting in traffic, and the occasional tire spin,(snow or sand) tiny friction particles have been let loose in the system as the in transmission screen is not a filter, just a screen.
The hot mix of burnt friction material, dirty oil, metal shavings get lodged into cracks, like dust in the corners that never get swept.
Now someone hooks up a high pressure flush of some harsh cleaner followed by fresh fluid, and washes out all of the crap.
Suddenly the old dried out seals, no longer flexable, have bigger holes to seal.
Old 03-24-2009, 09:41 AM
SuberNatural SuberNatural is offline
Level 10 in NJ makes a transmission too
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 03-24-2009, 10:06 AM
I forgot about them.
Old 03-24-2009, 10:33 AM
RoughSilver92 RoughSilver92 is offline
Just trust him FLUSHING IS BAD!
I, too worked at a dealership, (bmw, mazda, isuzu) and they stopped doing flushes on cars with high miles because the majority of the cars they flushed came back not too long after needing a new transmission.
And a more recent example: My girls dad just replaced the transmission on his girlfriends 05 ranger because her transmission was shuddering a little going into O/D and she took it to the dealer they flushed it and it got noticeably worse.
Old 03-24-2009, 12:38 PM
oregondave oregondave is offline
so basically the congealed crud serves to aid seals in doing their job of preventing fluid leaks? removing this natural 'stop leak' would then lead to fluid leaks...ok but how does this (other than the loss of fluid) lead to earlier trans failure?
Not trying to argue just trying to understand.
Old 03-24-2009, 01:32 PM
essveeexxee essveeexxee is offline
10 characters.
Old 03-24-2009, 01:38 PM
drain and fill is fine, just don't power flush, that is what stirs the crud up.
I suppose the lines at the radiator should come off and let it drain out of the radiator.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-24-2009, 07:44 PM
I do use compressed air to blow through the trans cooler in the radiator both ways to make sure it's clear, once both cooler lines are disconnected.
Old 02-21-2010, 06:35 PM
michael's Avatar
michael michael is offline
What Potholes ???
Shouldn't one bypass the trans cooler in the radiator in favor of an external trans cooler. I thought it was agreed that they become clogged due to the mesh inside pre '92. I did this years ago and have had no problems and better temps.
Wanted: Steering Wheel
Old 02-21-2010, 08:39 PM
Yes.
The current thinking is to bypass the stock in rad trans cooler with a medium sized one to allow more flow in the trans.
The trick is to allow full pressure, and still mantain a >150°f, and <200°f transmission pressure.
