Old 09-03-2008, 06:05 PM
redlightningsvx's Avatar
Collision Refinishing Tech
PS o-ring help
I just changed out the o-ring that goes to the metal line because of a tiny leak and now my power steering moans like chewbacca. It's all bubbly and such when checked. I also cranked the wheel left to right about 10 times but to no avail. Any help It's almost dark and am in a hurry!!!!!
p.s. Also when done turning the wheel and turning off the ignition the bubles go away.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-03-2008, 06:58 PM
Re: PS o-ring help
Just rechecked everything and turned the wheel several times again and the ps fluid oozed over the top of the tank. It wasn't a lot but enought to catch my attention. I never added or lost fluid when i changed the o-ring either so all of this is a first.
Seth
Past subies:
Other toys:
Old 09-03-2008, 07:51 PM
Re: PS o-ring help
Foaming fluid usually means that it's low, and the pump is beating it into froth. Try turning the steering wheel lock to lock without the car running and see if that helps.
Old 09-03-2008, 07:56 PM
Re: PS o-ring help
The fluid is fine and I turned the wheel with the car on and off. I dont know if this helps solve it but i did undo the torx bolts and jiggles it a little.
Seth
Past subies:
Other toys:
Old 09-04-2008, 05:10 AM
Re: PS o-ring help
bump................
Seth
Past subies:
Other toys:
Old 09-04-2008, 04:02 PM
Re: PS o-ring help
Fixed. I removed the whole ps tank and the o-ring on the bottom of that must have cracked when I jiggled it to change the other o-ring.
Seth
Past subies:
Other toys:
