Old 05-03-2008, 10:03 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Cleaning Coolant Reservoir
I took it off while looking for a coolant leak and it's full of gunk and crap inside so I figure I might as well clean it while it's off. Not as easy as it sounds lol. Anyone have any suggestions? What's a good cleaning solvent?
Old 05-03-2008, 10:07 PM
It's Just Eric's Avatar
Missing in action
pick up some simple green and a pipe cleaner brush. Dont even dilute the simple green, it should prettymuch break up whatevers in there, and the brush ought to be able to reach in all the crevices of the thing
R.I.P Cool Signature.
Old 05-04-2008, 12:42 AM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
the one thing i use to clean pretty much anything in my svx, liquid wise, is gas. im not sure if itll do the job for coolant, but i dont see why not. i use it to clean the oil pan, tranny fluid pan, etc. it evaporates and it cleans great. just make sure you let it all evaporate before putting things back together as im not sure that it would be good for fuel to be mixed with anything lubricating/cooling the car.
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 05-04-2008, 06:42 AM
zavikan zavikan is offline
hmm
Perhaps rubbing alchohol would do that trick better? Gas has other things in it, that don't evaporate, and would be hard to remove later. I dont know if it really matters for trace ammounts like that, but just my 2 cents
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 05-04-2008, 07:49 AM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
+1
I love Simple Green. I used it to clean off the caked on ATF from the Power Steering when it exploded everywhere.
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 05-04-2008, 09:18 AM
Boil water in a kettle, pour it in, and shake the container. That will take care of at least the easier stuff, so you can focus on the tough goop with a solvent.
Old 05-04-2008, 11:53 AM
Originally Posted by SVXyGirl View Post
+1
Just don't get it on the aluminum. It will discolor it.
Old 05-04-2008, 11:54 AM
Got a light?
Old 05-04-2008, 12:07 PM
SVXyGirl's Avatar
No worry...it was fine.
Rebecca
Past SVXs:
