245/45 r16 tires on stock rims
Hey, I was wondering if anyone had gone that wide? I really dont want/need tires this wide but I can get a GREAT deal on them new.
Basically just want to know if the rim is wide enough and if I will have any clearance issues? 225/50R16 245/45R16 Section Width: 8.85 in 225 mm Section Width: 9.64 in 245 mm Rim Diameter: 16 in 406.4 mm Rim Diameter: 16 in 406.4 mm Rim Width Range: 6 - 8.5 in Rim Width Range: 7.5 - 9 in Overall Diameter: 24.85 in 631.19 mm Overall Diameter: 24.68 in 626.87 mm Sidewall Height: 4.42 in 112.26 mm Sidewall Height: 4.34 in 110.23 mm Radius: 12.42 in 315.46 mm Radius: 12.34 in 313.43 mm Circumference: 78.06 in 1982.7 mm Circumference: 77.53 in 1969.2 mm Revs per Mile: 837.0 Revs per Mile: 842.7 Actual Speed: 60 mph 100 km/h Speedometer1: 60.4 mph 100. km/h Speedometer Difference: - Speedometer Difference: 0.681% too fast Diameter Difference: - Diameter Difference: 0.69% The numbers look close but I havent brought the car home yet (or ever owned an svx before) and the car needs tires. Thanks in advance, Mike |
That is my preferred size for 16s on an SVX!
No problems. Tom
They might be a little wide for the SVX rim as it's a, well I forgot what its width is. 7" or 7.5"?? I think it's a 7.5" which could work.
245/45/16 has always been my favorite size tire for some reason. If I were you I would go for it. Others may not agree though.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
245/45-16 is the tire size that the good Lord intended for this car when he conjured it up at the beginning of time. It will work perfectly.
I have that size on my FD rims, but it will also work fine on the stock rim. It is a bit harder to find tires this size, but if you already have some located you've already solved that problem.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Thanks for all the positive replies guys! Its been a lot of help
