#31
that WAS what I meant... but today I got a call from my father... his father fell today and is in really rough shape. among other things he broke his hip, and he is in his 90s...
so for now I have to plan on going up there next weekend. it is like a 60% chance i'll be going up. so don't plan around me. if you are still working on it and I am not going, I'll be over your way. sorry to let you down..
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
#32
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
#33
Flywheel is on, clutch is on, tranny is... not on. I was trying to mount the trans today, but it is a no-go. My jack stands hold the car only 20 inches off the ground and the combined height of the trans on the jack is 31 inches. I have to slide the trans under the car, then put the trans jack under the car and try to wrestle the trans onto the jack at that point. Impossible by yourself needless to say. So, I will wait until Seraph gets here. Pedals are out and so is the brake booster. Once Tom's kit gets here tuesday I can put the pedals in and attach the linkage.
So, once that second set of hands gets here it will be the home stretch. Put the trans on, attach the clutch line, bleed the clutch, bleed the brakes, wire for the reverse lights, and I think that should do it....
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 Last edited by sicksubie; 01-13-2008 at 03:39 PM. |
#34
Oh and I gaffed the rear end.... I need to swap the axles around from left to right... DOH!!!
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#35
Question about the wires I need to use for the back up lights.
This is the harness as it lays on the tranny. These are the wires that run off back by the tail of the trans These are the wires that run near the bottom in the middle of the trans These are the wires that are up at the top near the bell housing
#36
j/k. Calling you now to tell how we used to do it back in the dark ages. We did not have floor jack, I'd just get Og and Trog to pick up the Flintstonemobile and hold it up for me to install a REAL rock crusher transmission!
#37
the white connector holds the two wires for the reverse lights... The black connector has no function in the swap
Tom |
#38
Bobby, Do you have an engine lift/hoist?
If so, I use it to install 4EAT's on my own. - Slide the trans into place under the car - Fully extend the hoist to the area behind the throttle body and drop a long chain down to the trans. - Use the hoist to lift the heavy end of the trans and either use muscle or a small floor jack to lift the tail - Slide the trans jack under and get back to work slacker
#39
Bobby what did you mean swap the rear axles, which goes were?
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#40
The pass side axle has a longer stub on the differential side. I simply put the driver side axle in the pass side of the diff.
#41
I must be missing somthing the R 180 rear axles are the same left and right, the SVX axles are different.
#42
I have STi axles that I am using..... pretty sure that one had a shorter stub... Now I am going to check before I take the rear end out. I only started wondering because once the axle on the pass side popped in there was no thread to catch the axle nut on. Also the driver side is nigh unto impossible to get to pop into place.
#43
Following your comments about swaping I phoned a rally guy and asked him he says they are the same. It might turn out that 1 of your axles is not a STI one.
Tony
#44
Tranny is in, slave cylinder is on, starter is.... not on. Do I have to drill for the lower mounting bolt?
#45
They all definitely are as I personally pulled them off of a 2007 STi.. That issue has been resolved though and my rear end is set...
