Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #466
Old 11-02-2007, 09:31 AM
Overheard in YT's classroom.
Originally Posted by TomsSVX View Post
grumble grumble.... murder.... grumble... damn homeroom.... grumble
"HEHEHEhehehe, "Old Man Johnson" dosen't remember what its like to be a kid"
"Yea, he's just an old grouch!"
Old 11-02-2007, 12:05 PM
cdigerlando cdigerlando is offline
Originally Posted by sicksubie View Post
I think that we were seeing knock because boost was coming on too fast and too soon. The bypass valve spring is too stiff which is also why we are only seeing about 10-11" of vacuum. Tom said that it should be around 15-16" and the reason it is not is that we actually have small amounts of boost occurring at idle. I will let him explain it further though.
It sounds like you are still chasing a vacuum leak. If the bypass is working properly it should not be leaking. Do you have any way to plug the bypass line and run the motor at idle only to see if this fixes the vacuum leak?
Boost comming on quick is the wonderful thing about superchargers. I bet what is happening is the cams are allowing the supercharger to work much more efficiently, causing your boost to go up throughout the rev curve. I think you may need to do some more tuning with this motor. I'm glad you are bringing this up, as this will be an issue for all of us to deal with.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 11-02-2007, 12:12 PM
sicksubie's Avatar
His motor isn't even built yet though and he won't be running a stage III set up......
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 11-02-2007, 12:15 PM
sicksubie's Avatar
There is NO vacuum leak and I am 150% sure of that. I took the belt off the bower and the car idled beautifully. You are right about the beauty of the S/C being early boost. That is great but not when your software does not take that into consideration.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 11-03-2007, 07:40 AM
I got to thinking last night, I don't think the cams will cause more boost. In fact they should reduce the boost since they will "consume" air faster. Hard to tell though. Wasn't the tune done on a 9 lb. pully? If this was the case, this might be the problem with your tune.
Chuck D.
Old 11-03-2007, 08:48 AM
i was going to say that but I figured you would realize what you were saying. I am buying a rom reader/writer/eraser in the near future and I have a flashable chip for it. Using that with my g-tech I will try my best to get a better tune on the ol girl
Old 11-07-2007, 01:18 PM
How much does one of those cost?
Chuck D.
Old 11-07-2007, 02:38 PM
probably gonna cost close to $1k for the hardware I may have a co-sponsor for it but I need to level out the order first
Old 11-07-2007, 03:16 PM
That's a good price.
Chuck D.
Old 11-07-2007, 03:21 PM
Got my heads back from the machine shop. They look nice with the pretty new valves. Got the block back, but had to return it to have some grooves cut in the semi decking to allow some better coolant flow, since the inserts extend into the water passages. There is some room between the gasket and the bottom, but I want more room for sufficient flow. Also he needs to cut rings on the last three of my pistons. Hopefully he will finish by the end of the week so I can start to slowly assemble everything. I also received the cometic head gaskets and other subaru motor parts. I'll take pics as I progress through the assembly.
Chuck D.
Old 03-01-2012, 02:41 PM
Re: Engine Build Progress and Questions
we could have even called you Bill...
THIS NEVER GETS OLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-01-2012, 03:22 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
and you dig up a thread from 2007 to abuse me with?
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-01-2012, 03:54 PM
I have been pouring over engine build threads all day long.
At least THIS^ part was fun!
Old 03-01-2012, 04:20 PM
SomethingElse's Avatar
word words wording
Ive been doing some research as well. Where the heck can I get parts from anymore?? I need pistons,cams,rods..possibly valves...AHHH!
Eric
Old 07-21-2016, 01:42 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Reviving a thread from the dead! I need to get a hold of LAN. Building an EG33 for boost .
LAN if you see this I sent you an email on 7/21/16. I need to know if you still have some engine goodies on hand.
-Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
