Old 01-16-2007, 09:22 AM
svx0104 svx0104 is offline
1SICKSVX
Where to get wheels ??
Just wonderin where everyone get there aftermarket wheels from i am having a hard time finding them
Old 01-16-2007, 10:08 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
tirerack.com
wheels.com
e-bay
Old 01-16-2007, 10:25 AM
http://svx-motorsport-accessories.stores.yahoo.net/
Old 01-16-2007, 11:14 AM
1SICKSVX
and what would look good on it any body got pics of the svx with different wheels like sizes and styles
Old 01-16-2007, 01:02 PM
dannmarr's Avatar
I work for my SVX
Check out 'personal lockers'.
Old 01-16-2007, 01:12 PM
Also, check out "Customer Cars" on the link I gave you.
Old 01-16-2007, 07:35 PM
It's Just Eric's Avatar
Missing in action
Also try the search button. theres mabey 4 billion threads on wheels and wheel choices, sizes, ect, most with pictures so you can get an idea of what looks good
R.I.P Cool Signature.
Old 01-19-2007, 09:36 AM
1SICKSVX
any body put the 300zx wheels on there car i am trying to keep a oem type look but the wheels on the car i am getting are beat up preatty good and i like the 300z wheels so any pics or links to pics would help
Old 01-19-2007, 10:08 AM
shotgunslade's Avatar
Got my Rota's from Subydude.com Was $700 for the four, including shipping. Still says $175 per each, didn't see anything about shipping.
