Old 09-12-2005, 06:38 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
completed pics of the wrx
http://www.subaru-svx.net/photos/user.php?solarsvx|29248
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 09-12-2005, 09:17 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Pics looks great. How much boost are you running and have you sorted out all the bugs since your last dyno run?
Still on the stock trans? How's the clutch holding up? Any 1/4 mile runs?
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-12-2005, 09:19 AM
24-25 psi on 20% methanol injection
no runs on the new hi boost set up soon though,
still stock trans and clutch with 25k on it not a single issue with the car its ran flawless, good tuning and good driving .
Old 09-12-2005, 09:22 AM
Chiketkd's Avatar
Any plans to get her re-dyno'd? Btw, is your red intake manifold from the JDM STI?
-Chike
P.S. Nice looking Rex!
Old 09-12-2005, 09:34 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
anybody else getting a bad link now?
Brian
Old 09-12-2005, 09:39 AM
Chiketkd's Avatar
I got a bad link as well, but I just went to Solar's locker by clicking on the 'Personal Lockers' link in the upper right hand corner.
This link should work:
http://www.subaru-svx.net/photos/use...solarsvx|29248
-Chike
Old 09-12-2005, 10:28 AM
yea some time after nopi's in atlanta im going to re dynoe it, i need to replace the spark plugs and stock headers, along with a turbo inlet hard pipe instead of the rubber samco wich seems to be smashing together under boost load,
its a never ended battle LOL
Old 09-12-2005, 11:32 AM
mbtoloczko's Avatar
sans SVX
Is that 20% methanol and 80% water injection? Or do you mean 20% methanol/80% gasoline?
Mychailo
Visit my locker
Old 09-12-2005, 12:06 PM
20% methanol injection the water injection is set to run 100 methanol out of all the research methanol seems to work best
meth on pump gas equals to abought 108 octane give or take some on how much u inject, and im not sure if this 100% the case,
i havent had any issues with knock the ocasional here and there knocks but everything seems good
