Old 01-29-2010, 08:42 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
Question transmission question....
dose a legacy have the same transmission as an svx and if so what do i have to do to swap it into an svx.
I has teh FWD LS-L
Old 01-29-2010, 09:40 PM
Re: transmission question....
It's different but an easy plug and play swap. You will need the rear differential to go with it because the gear ratio is different. Do a search there's tons of info on this.
Old 01-29-2010, 10:16 PM
92_LSL's Avatar
what years work ?
I has teh FWD LS-L
Old 01-30-2010, 05:32 AM
I believe '96 to '99 are the ones use the search feature.
Old 01-30-2010, 02:56 PM
I believe '96 to 'EARLY 98s without the spin on filter from a Subaru that has a 2.5 engine are the ones use the search feature.
Fixed it.
How to is in my signature.
Old 01-30-2010, 03:37 PM
92_LSL's Avatar
i honestly don't know what is better. recently i went on u pull and pay's web site and found four legacys, one is a 1990, the second is a 1992 and the last two are 1995's . will any of these work ?
I has teh FWD LS-L
Old 01-31-2010, 08:55 PM
Originally Posted by 92_LSL View Post
so what do i have to do to the diff to make it work ?
Fixed it.
If you get me the # on the bell housing I can most likelytell you the ratio.
