Old 12-11-2011, 01:04 PM
SubaruJawn's Avatar
SubaruJawn SubaruJawn is offline
got my SVX 12-8-11
Re: Vexine: 1992 SVX
Confused again ... Looking at the power steering fix , what exactly did you do? I see a hose with clamp also see a hose with a metal pipe and clamp. I see what looks like a nipple coming out of the bottom of you radiator cooler with nothing attached . Now the body work . What did you use to do that ? Did u back it or just fill it with what looks like Fiberglass impregnated Bondo or we called it Duroglass. My body shop said they no longer weld in new sheet metal . They now cut out the rust and Epoxy Glue in a new piece of either fiberglass or sheet metal .
sorry for the confusion, the hose is connected but not in the picture.
i used fiberall and fiberglass to fix the holes.
i will later paint under the plastic with Rusolium paint.
i still weld at times, this time i chose not to.
Old 12-11-2011, 08:56 PM
I just checked the video tour of your SVX VERY NICE I wish I saw it before you bought it I would not have made any neg comments. The hip in the windshield , can it be repaired? The antenna is it stuck or just doesn't go all the way down? The sun roof is the same on both the SVX I have owned (lazy to open). The 94 is a little better , it doesn't always need the little push.Thr roof is in real great shape, most have faded. The motor sounds strong and so does the tranny.Nice smooth idle. Quiet exhaust..Side glass almost perfect no scratches. Seats have normal wear.Fix the rust and touch up the other areas and you got a nice looking and running SVx you done good
Old 12-13-2011, 09:58 AM
SubaruJawn's Avatar
got my SVX 12-8-11
vexine failed inspection due to 3 minor things
1. Front Sway Bar Links
2. Right Rear Tire (can temporary fix no $)
3. Exhaust pipe on drivers side needs extended (can fix no $)
Old 12-13-2011, 10:14 AM
Cheapest front endlinks I have found: http://www.ebay.com/itm/2-FRONT-SWAY...item3a6042331d
Old 12-13-2011, 10:17 AM
SubaruJawn's Avatar
got my SVX 12-8-11
couldnt i just replace the rubber on them ?
Old 12-13-2011, 10:25 AM
You could just replace the boot if there's no play in the link itself, but I don't know where you'd source them.
Old 12-13-2011, 10:38 AM
SubaruJawn's Avatar
got my SVX 12-8-11
theirs play, why it failed.
Advance
Old 12-13-2011, 10:48 AM
I would just replace them altogether.
Old 12-13-2011, 10:56 AM
SubaruJawn's Avatar
got my SVX 12-8-11
if its for the best, i'll go that route.
the link you gave me is for both left and right ?
Old 12-13-2011, 11:02 AM
Yea, the pair.
Old 12-13-2011, 11:05 AM
Always something.... RATS. will that mean a front end or 4 wheel alignment? I find it strange that u needed it inspected. In CT only if it is an out of state car does it need to be inspected .
Old 12-13-2011, 11:30 AM
PA has STRICT yearly inspections
Old 12-13-2011, 11:48 AM
No cost tire problem what was wrong?
No cost Exhaust pipe what was wrong.
Old 12-13-2011, 12:34 PM
subeman90's Avatar
Soobologist
his tip is missing so it exits under the car before the bumper cover. easy fix.
as for the tire I'm sure he will come up with one and put it on. No biggie there either
Sorry I didn't say anything about the exhaust John...I have a PA inspection License and I should have pointed that out to you. my bad.
15 OBW premium w/eyesight
Old 12-13-2011, 12:35 PM
subeman90's Avatar
Soobologist
nope, it is just endlinks. that is an easy fix too.
