Old 02-25-2010, 08:17 PM
Aftermarket Camshaft Options
I'm rebuilding my engine this summer, mainly with the goal of getting it back up to full running spec, but I'd also like to give it a little more grunt. My current thoughts are some aftermarket cams and possibly mild head work. However, this has lead me to wondering what the camshaft options are. I've searched, I swear! Here's my list so far:
ECUTune: 3 different profile sets listed.
Web: No SVX listed on their website. Do they have stock profiles, or is every job a one-off?
Delta: Same question.
Are there any other options? And for those who have aftermarket cam experience, do you have any suggestions?
If this thread generates some solid information I'll change this post to reflect the list that comes together.
Old 02-25-2010, 09:27 PM
Nevin's Avatar
Nevin Nevin is offline
Re: Aftermarket Camshaft Options
I had a crower cam ground for my Mazda a few years back. They didn't have anything listed, but someone told me about them and I was very happy with the results. If you're looking, they're at least worth a shot. Just call them up, ask for the cam shop, and tell them what you want.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 02-26-2010, 02:17 AM
What is your budget for
1- Reground cams
2- New lightweight billet cams?
Old 02-26-2010, 05:28 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
I know nothing about Web other than they are way expensive, although all the "best" EG33s use them so theyre prolly the best.
Delta will regrind your cams for 200 dollars per cam, do a search cause I dont have the exact numbers in my head but you can send them just your intake cams and have a pretty good improvement for 400 dollars. I'm debating doing that myself, but I'm so close to being done I can taste it haha
Old 02-26-2010, 09:43 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
The reason the Web Cams mentioned are expensive is because they're hardface-welded then reground to maintain the stock base circle diameter. If you just had them reground the price is FAR less.
Most places that do hardface cam welding charge about $25 per lobe, so you can see the costs add up quick!
Bob Légère
EG33 Impreza tweaks
Old 02-26-2010, 11:27 AM
RallyBob's Avatar
FWIW, I did finally discover exactly which cam profiles Jack's EG33 is running. They're based off Web's Suzuki 'Hayabusa' cam profiles.
Intake Profile:
.445"/ 11.3 mm valve lift
244° duration @ .050"
268° advertised duration
Exhaust Profile:
.460"/ 11.68 mm valve lift
These are VERY fast opening cam profiles judging by the relationship between the advertised duration and the duration @ .050".
These were certainly a one-off cam design for an EG33, based on the airflow the heads were making (which I faxed to Web).
Bob Légère
EG33 Impreza tweaks
Old 02-26-2010, 04:46 PM
My budget isn't terribly limited, within reason (I am still a full time student). $1000 is easily doable, probably up to $1500 if required.
Bob,
That profile is meant to run with the modified valvetrain Jack's car has, correct? I would guess it's too aggressive to work with the factory valve gear? How is the "streetability" of that sort of arrangement?
Chike had posted a set of intake cams he installed:
8.0mm of lift, 247 degrees duration w/ the entire profile retarded by 7 degrees
Seems very conservative compared to the 3.3RS.
Old 02-26-2010, 05:13 PM
Correct me if I'm wrong but I'm assuming the 3.3 RS has undergone a full conversion to Impreza valves and lifters or whatever. I think keeping most of the stock stuff (and your motor non interference) will limit how much you can modify your stock cams.
Old 02-26-2010, 08:27 PM
That was my understanding as well. I think that profile will only work with the solid bucket conversion, which is out of my budget, ability, and need.
Old 02-27-2010, 08:47 AM
RallyBob's Avatar
Yup, you guys are both right. Those cams are of the solid tappet variety, and won't work within the limits of the stock valve springs and valve lengths either.
Bob Légère
EG33 Impreza tweaks
Old 02-27-2010, 04:42 PM
Bob do you know what the lobe centers or valve timing is.
Old 02-27-2010, 04:53 PM
dont know if these would work but they came up while searching SVX
http://www.sportcompactonly.com/Engi...-5_pl-1020.htm
Old 02-27-2010, 05:24 PM
RallyBob's Avatar
I believe they're ground on the stock centerlines.
Bob Légère
EG33 Impreza tweaks
Old 02-27-2010, 10:24 PM
This is the effect of the economy. These guys wanna sell everything to anything
Old 03-14-2010, 06:40 AM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
Thinking the same as I'm gonna rest most of the power ups on my spare engien build on the head work. Don't know what I'll do for cams. Maybe even leave stock for now but now about the coverter to solid. How likely would a general shop motor shop beable to just go right ahead and do this without having to research or what not? Especially if I bring them to a shop that has worked with EJ's in the past. If i'm better off finding someone who's done it before who would be a good idea to bring/ship them to? Bob are you dirrectly an option on this? I just want to get teh heads built up and clean the block back up with new seals and such, maybe Cosmetic HG's and get it set to drop in.
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
