Idle Air Control Valve
Need one. Stat!
Re: Idle Air Control Valve
Where is that and what does it look like
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
Attached to the bottom of the throttle bodies. It's got one big port to a big vac line that goes to the intake. One grey plug with 3 wires, 4 bolts holding it to the throttle bodies.
if that is the intake air control valve what is the valve bolted to the cross over pipe under the intake?
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
That is the AACV = auxiliady air control valve. The IACV is controlled precisely by the ECU. The AACV is just open when cold, and closes as it heats up. It's to provide some extra air when the engine is cold.
Part obtained.
