Old 12-31-2007, 07:00 PM
jeffast jeffast is offline
I kill more trannies then god
Originally Posted by benebob View Post
Go to Hucks write up in his locker for the rear dif info. I wouldn't reuse a torque converter from a bad tranny (if that's the case). It'd be like reusing your motor oil after a piston imploded. At the very least I'd have it cleaned professionally.
+1
you can get a rebuilt torque converter for $100 or less i would get a new svx one, just my 2 cents
1991 xt6 eg33?
1993 gc track car
Old 01-01-2008, 09:54 AM
Mr.EG33's Avatar
Mr.EG33 Mr.EG33 is offline
So if I took the flex plate can I just use the Imprezza tq converter? Also I looked in Hucks locker and I didnt see a Diff write up?? Is it in another write up?
Thank you everyone for you assistance
Old 01-01-2008, 11:17 AM
Forget the Impreza rear diff unless that Impreza came with a 2.5 engine.
How to is in my signature.
Forget the Impreza TQ, it will overheat.
Forget the Imp flexplate.
( however Subaru Parts .com lists the Imp# as one that will work)
Like Ben says have your TQ professionally cleaned.
If you can buy SVX TQs for $100.00 I want three to start.
Old 01-01-2008, 12:05 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally Posted by jeffast View Post
+1
What from a company that spray paints the outside nice and shiney and slaps on a useless warranty? Me want to know where you're getting one for at that price!
Old 01-01-2008, 12:30 PM
M.Berger Co. in SouthSide Pgh.
Spray it yellow and its NEW!
Old 01-01-2008, 04:52 PM
Yep,
You can use the Impreza Tranny, with no mods....to use the Impreza Torque Convertor, you need a Impreza Flexplate.
I too say if you want to use the SVX Torque Convertor, have it rebuilt...cost me $175 the last time I had one done. (or just use the Impreza one)
On the rear diff...be careful, as many Impreza have a "smaller" rear diff....make sure it has the 5-bolt side plates on it, or you can't swap the gears into the SVX LSD unit....Use SVXfiles write up to swap the ring and pinions.
And the reason you can't "just use" the Impreza rear diff as a direct bolt in, is because the SVX rear LSD uses unique axles, that no other Subaru rear diff uses (that I know of)
If the Impreza rear diff doesn't have the 5-bolt side plates, then just get a Legacy rear diff with the same ratio as the Impreza one...
Hope this has been helpful
Old 01-01-2008, 05:37 PM
It has been my experience that an Impreza torque converter will cause the trans to overheat.
I will never again install an Impreza TQ behind a 3.3.
Old 01-01-2008, 10:55 PM
i got a remanned, one, thats shop price through a friend.
i didn't think it was that good a deal.
what do they usually go for?
edit: saw OT's post, damn, that was a good deal. i have a friend who rebuilds these for a living i bought it through his account
1991 xt6 eg33?
1993 gc track car
Old 01-02-2008, 10:50 AM
Mr.EG33's Avatar
So what direction should I go???
svxfiles
OR
huck369
Yep,
Its a 96 Impreza 2.2....
Thank you for any info provided
Old 01-02-2008, 11:12 AM
svxfiles
OR
huck369
The Impreza 2.2 probably has the right rear diff, but just check to be sure it has 5-bolt side flanges...
I'm pretty sure only the EJ18 Impreza's had the smaller diff...
But it's really easy to see the difference in the side plates.
Old 01-02-2008, 11:45 AM
Mr.EG33's Avatar
Well this is definitly a relief!!!!
Now the question is the tq converter 2.2 converter with flex plate - will it overheat like svxfiles said or will I be fine like huck said? I really dont have the $$ to get my SVX tq converter cleaned professionally
Thank you all for your help
Old 01-02-2008, 02:51 PM
What happened to your old trans?
If the diff exploded you can reuse it by just changing the trans oil over and over again.
I used to change out 6 quarts of trans fluid every 6000 mile engine(synthetic) oil change.
Oil is cheap!
BTW, getting the TQ cleaned is cheaper than having to re-do the job.
Old 01-02-2008, 03:57 PM
Mr.EG33's Avatar
Oil is cheap!
Well my old trans use to flare between 1st to 2nd and 2nd to 3rd depending on how warm it was out side, then I took a lil trip (about 80 miles) and on the way back I got a flat so I used a spare, ofcorse then I had to take the streets which was fine with me.... I was driving @ about 35mph and I noticed a lil slip but while doing a steady 35mph and I was like well what can ya do...... So I came to a stop @ a red light and after it turned green I took off slow like usaual and my tranny wouldnt shift out of 1st gear..... So I would hit the gas till about 30mph and then slow to 5 - 8mph before I hit the gas again so I dont hurt the engine.... well that happened for the last 2miles of the trip till I got home. Well when I stopped the car she was smoking and I smelt burned tranny fluid (I already knew the tranny was going out) so yeah thats what happened to my 4EAT....
The diff I have is fine I thought I just needed to change it because of the Impreza tranny
I do all my own work by myself - I just never tried to rebuild a tranny.... I just need to know if the Impreza 2.2 tq converter will work fine?
Old 01-02-2008, 07:05 PM
I'm not going against SVXfiles on the Imprza TC, but I think with the lower final drive, and a good tranny cooler you'd be OK....but having the SVX TC rebuilt would be the ideal thing to do, but I understand about working on a budget.
Old 01-02-2008, 10:53 PM
Mr.EG33's Avatar
OK, so I for now I can use the Impreza 2.2 tq converter w/ the flex plate because of budget which should be ok w/ a trans cooler and proper maintenance
Awesome!!!
The 3.3 SVX tq converter is better to use but needs a professional rebuild...
(Ill ofcourse keep the OE tranny till I have the $$ to rebuild because I want to keep all matching #'s; so the SVX tq converter isnt going anywhere either so when I have the $$ Ill fix it correctly)
I do all my own work so I should be fine without having to spend so much $$ now! (gotta love the holidays )
Thank you all for your understanding and knowlage
