Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #151
Old 10-28-2004, 05:48 PM
Originally posted by Matthewmongan
any way to change the power distribtion of the svx from 90-10 to the euro spec 35-65
I'm also curious as to how you can get 65% power to the rear wheels since there's always direct power going to the front tires.
Old 10-28-2004, 05:49 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
one quick tranny question. i dont want to derail the topic of this thread but it their any way to change the power distribtion of the svx from 90-10 to the euro spec 35-65
Get a new transmission. The torque split is different because they have a planetary gearset rather than a viscous coupling.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 10-28-2004, 06:50 PM
Originally posted by NikFu S.
I'd be down for that.
90-10 is stupid anyways.
Di and I drove around the other night with the select moniter hooked up to watch the F/R power split. Most of the time it was around 77%, at wide open throttle it was 50/50, in park it said 95%. For years the Subaru Reps said 90/10, but at idle, in park it says 95%.
Old 10-28-2004, 07:31 PM
mbtoloczko's Avatar
sans SVX
Originally posted by svxfiles
Di and I drove around the other night with the select moniter hooked up to watch the F/R power split. Most of the time it was around 77%, at wide open throttle it was 50/50, ....
Very cool info.
Mychailo
Visit my locker
Old 10-28-2004, 07:32 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
i think my awd is broken
Old 10-28-2004, 07:50 PM
I think that the moniter measures the duty cycle that is sent to the C sol. so the 95% would be full voltage to the solenoid fully opening it , on your model this is fully disengaged. I got a VTD box which works the oppersit way, 95% on it, is fully engaged.
Old 10-28-2004, 11:57 PM
Mine too.
Old 10-29-2004, 01:51 AM
ThetaReactor
The STi trannies are 50/50 base, no?
Anyhoo, back on topic...
How's the chip set up for Stage III? I don't think I've seen anything about that. Will it have the NOS code, the 87 octane code, or something completely new in the second slot?
Old 10-29-2004, 02:26 AM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
The fuel and timing tables will have to be different for stage III. The power from the supercharger will not be as linear as that of the nitrous. Also, I'm guessing that it will not be set up to run on 87 octane... especially since premium was the desired fuel in stock trim, we'll most definately need premium to help stave off knock with the additional pressure and heat created by forced induction... as well as the timing being retarded.
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
Old 10-29-2004, 03:12 AM
ThetaReactor
Yes, I'm quite aware that it'll take a completely new config to handle the boost. I'm just wondering what kinds of alternate option it might offer.
Old 10-29-2004, 04:43 AM
What do you mean?
-Aaron
Old 10-29-2004, 05:56 AM
ThetaReactor
I mean that stage I has Performance + 87 octane mode, stage II has Performance + nitrous mode, stage III has boost + ????...
Old 10-29-2004, 07:50 AM
alex_umn alex_umn is offline
I live in a drawer!
Send a message via AIM to alex_umn
Maybe there could be a clutch on the supercharger drive pulley that would be tied to the trigger for 87 octane code? So, flip a switch, and then you can run cheap gas and have the supercharger turned off. That would be sweet!
Wonder what else could be put on such a switch...maybe electric control of Koni strut inserts?
Front to back, sorta: Claret 1992 Subaru SVX LS-L, JDM STi open front diff six speed, STi tranny mount, Kartboy shift bushings, WRX CD changer, rear R180, battery in trunk, Stebro exhaust.
2000 Specialized RockHopper A1 FS, converted to singlespeed 36:15.
I like my cars with too many gears and my bikes with too few...
Old 10-29-2004, 08:14 AM
Yeah, that'd be pretty crazy!
I'm going to bet that it'll only be one set of tables since allowing the supercharging to be turned off won't be in the picture (at least not currently), and nitrous with the blower would be pushin; it for now. Also, a lower octane set wouldn't make much sense since it would kinda be like shooting for less power due to not allowing the timing to be as advanced as possible for maximum power. I'm just making a guess... but I'm pretty sure that is what it will initially be.
-Aaron
Old 11-04-2004, 08:39 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Talking Back to Business!
Okay, what's the latest on the Stage 3 front? I'm in definite need of a digital pics fix of a supercharger on a modified SVX intake manifold!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
