Old 04-06-2013, 09:26 PM
Re: Tracking down the latest leak
Originally Posted by Huskymaniac View Post
So, remove the old clamp, check the hose, leave it if it doesn't look damaged, install new clamp. Is that right?
Yes.234567
Old 04-07-2013, 11:18 AM
Huskymaniac's Avatar
Uses the ignore feature
Took the old clamp off and put a new one on today. The hose had a small indentation where the tab dug into it but it seemed otherwise intact so I just slid the new clamp on over it and tightened it down. I started the car and ran the tranny through all the gears, as I had done yesterday to find the leak, and it didn't seem to be leaking. So I will see how it goes for the next day or two.
Overnight, a couple of new spots did show up under the car. They were small and obviously took a long time to drip down. One spot came from the shield around the exhaust just in front of the driver's side precat. The other came from a black tube that runs under the transmission. I assume that is some crossmember to hold the tranny? I wiped everything down and will see what new moisture shows up over the next couple of days.
I bought four clamps just in case I need to replace the clamps on both sides of these lines. One thing I did was pre-shape these clamps. They don't exactly come shaped in the ideal round form. I took a socket from my socket set that had about a 16mm OD. I loosely tightened the clamp onto it and then used a pair of needle nose pliers to shape the clamp around the socket. I then tightened further and repeated. I turned it around and repeated on the other side of the clamp. They came out looking nice and circular and the tab seemed to slide nicely around the hose.
Tony
