Old 02-10-2013, 08:38 PM
redlightningsvx's Avatar
Collision Refinishing Tech
side project need advise
Well my buddy ended up getting a 1998 Eclipse GS-T for practically nothing. It has a jdm motor w/70k on it
stock turbo and an EVOIII turbo w/ stainless steel manifold
cat back exhaust
new clutch/slave cylinder
manual boost controller
Wideband a/f,boost and oil pressure gauges
The spare original turbo block
body kit/custom paint/18inch rims
That sums it up but need advise on tuning the boost and all that since I really don't screw with those at all. Any input at all on what we should do to it would be appreciated.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 02-11-2013, 03:08 PM
2006eg33 2006eg33 is offline
Re: side project need advise
look into ecmlink/dsmlink.
it allows you to take full control of the stock ecu. no need to buy a standalone or anything.
Old 02-11-2013, 05:43 PM
Does it have preloaded maps to flash to it or do you tune yourself?
Seth
Past subies:
Other toys:
Old 02-11-2013, 06:04 PM
tune it yourself.
basically you plug it in, it pulls up the stock tune. and then you adjust it from there. it's insanely easy to use. i am tuning a talon tsi right now with it.
calibrating injectors is a matter of a couple clicks, most readily available injectors are already well documented for when you adjust deadtime and such.
Old 02-11-2013, 08:55 PM
I'll let him know cause we got this bigger turbo and cant use it without destroying the motor. The kid who had it last wired and plummed everything wrong
Seth
Past subies:
Other toys:
Old 02-14-2013, 11:46 AM
here's a couple pics so far
New pilot bearing
New Prothane motor mounts
New Clutch kit
Old trans mount
Teh P0w3rz
Seth
Past subies:
Other toys:
Old 02-14-2013, 03:03 PM
what turbo are you using.
we are using a hahn super 20g
Old 02-14-2013, 10:27 PM
Its got the stocker in for now untill we get injectors and such but the one above is an EVOIII 16g turbo w/ stainless steel headers
Seth
Past subies:
Other toys:
Old 03-02-2013, 10:33 PM
Well change of plans, noticed a puddle of gear oil under the trans after I moved it and noticed a crack on the rear housing. I went to take it of so I could weld it and found one of the pinion shafts has some play and filled the rear housing full of metal shavings. Better I find it now then in the car.
Seth
Past subies:
Other toys:
Old 03-02-2013, 11:33 PM
cat back exhaust
I am going to send you to a guy named "Crowbar".
I believe that Dave can help you.
Old 03-03-2013, 12:05 AM
Tom I HATE DSM's. Good thing is that its not mine, and its my buddy's money he giving me to fix it.
Seth
Past subies:
Other toys:
Old 03-03-2013, 12:16 AM
Here's the damage
File Type: jpg 553179_471609556239172_1799690919_n.jpg (31.7 KB, 141 views)
Seth
Past subies:
Other toys:
Old 03-03-2013, 03:14 AM
Actually "Crowbar" is a real serious mechanic!
He has made some stupid fast DSMs, and Cavaliers!
He is on 160 below Berlin PA and knows these cars.
Old 03-15-2013, 08:10 PM
Found the culprit
File Type: jpg 208201_477556662311128_1163101346_n.jpg (44.3 KB, 143 views)
Seth
Past subies:
Other toys:
