Old 02-07-2013, 10:28 PM
davew833 davew833 is offline
11 mpg ????
Thought I'd start a new thread on this since I had a few comments on my PCV thread relating directly to my MPG problem..
'94 SVX LS 2WD... averaging about 11 MPG lately. It was suggested in my other thread that it might be a stuck open injector, a fuel leak, or bad cats-- Is there any way to test for these specifically?
It passed Utah emissions test in December with no problems. No Check Engine codes either.
I ran a bottle of FI cleaner through it last week and it didn't seem to have much effect. This week's attempt to improve things involves replacing the PCV valve and the under-manifold vacuum lines (can't really do one without the other...)
I did find when I removed the throttle body "snorkus" that one port was folded under causing it to not seal to the throttle intake correctly, and that the inside of it had a pretty thick coating of engine oil.
Any other suggestions?
davew833@yahoo.com
Former 6-time SVX owner
Old 02-07-2013, 11:31 PM
Re: 11 mpg ????
Are you using 87 octane, or 91? When was the last time the plugs were changed, and do you know what kind were used?
Old 02-07-2013, 11:40 PM
bishop bishop is offline
Re: 11 mpg ????
have the brakes ever been done, i lost a few miles when my were sticking.
