SVX won't start after accident
To All,
Any help with this will be appreciated since my engine knowledge is limited. My son was in an accident with my LSi in November where he rear ended someone at low speed. Their rear bumper rode over our front bumper and crushed the radiator into where it was barely touching the engine. The air bags didn't deploy. I removed the damaged parts, had a new radiator support put in, and tried to start the car. It cranks but doesn't start. I can hear the fuel pump running if I'm underneath the car. Tomorrow I'll spend some time trying to figure this out. Any ideas will be appreciated. 1. I'll pull the fuel line off after the filter to see if there's pumping gas. 2. I'll pull a spark plug to see if they're wet (injectors) and if they have spark. 3. Is there an "accident relay" or "after emergency mode" that turns something off in the ignition circuit when in an accident? -Does the "fuel rollover switch" have a role? -Does the security system have to be reset? 4. I'll check for vacuum hoses that came off (didn't see any) and harness connectors that may have come off. The harnesses, at least in the damaged area, seemed to be undamaged. 5. I'll look at ground connections. 6. The "ambient air temp sensor" looks OK but doesn't the ECU uses this for air mixture? I assume I can just check the temp gauge in the car to see if this works. 7. Are there parts that may break with impact that wouldn't allow the car to start at all? -Mass Air Flow Sensor -ECM -Crank Sensor Thanks in advance, Dennis |
Re: SVX won't start after accident
My daughters Outback wouldn't start after a worse accident than you describe. The timing belt had jumped a couple of teeth.
This is probably not the case in such a minor collision but a possibility. |
Thanks,
I'll keep that in mind as a possibility. I'll check for CEL codes too. . |
Thanks for the help. I didn't take pictures and it's largely repaired, except for the hood, bumper cover and fenders. The wiring harness looks OK as just the tip of DS fender was slightly damaged. I'll check the CEL codes tomorrow also.
Thanks again, Dennis |
That was my first thought.
I used an OBDII scanner on it and it there were no codes. There was gas being delivered, at least, to beyond the gas filter. I didn't pull a spark plug yet as I only had a few minutes to spend today. I don't see any vacuum lines knocked off. I checked electrical connectors around the engine and they appear OK. The battery wasn't displaced and the cam sensor wasn't hit. Externally, at least the connectors on the cam sensor and crank sensors seem OK and there's no evidence that they were hit or disrupted. I pulled out a crank sensor from my parts car and it looks pretty nondescript. What do I look for physically that would indicate that it's bad. By the way, I was told that it cranks only. It does seem to want to start for 1 second and then it only cranks. If it's left for a while, it will do the same thing.
I looked at the mass air flow sensor. The tiny element inside looks OK. If something were broken that I can't see, is it possible that the MAFS can cause it to not start?
Thanks, icingdeath88, for the ECU and MAFS suggestions. I think I'll leave the crank and cam sensors alone for now so I don't screw them up, since there were no codes detected by my OBDII scanner. I'll check the ECU connections and try a MAFS from my parts car (engine ran fine before it was retired-216K miles and needed too much else)
Damn!!! I thought the MAF Sensor was going to be it. Before I replaced it with the Parts car MAF sensor, I tried to start it and it ran for 2 seconds this time, then nothing. After replacing it with the parts car MAF, nothing but crank. I went around checking electrical connectors, including under the dash, and everything seems OK, There is spark with a regular rate when I pulled the plug. It's not wet, but I get a whiff of gas from it. I don't see any vacuum hoses off. Am I looking at a timing belt that jumped? Any other ideas? Is it time to put it on a truck to the dealer?
It's easy enough to check the timing yourself. Also, a trained ear can tell if the timing is off even without it running.
You may have a bad coolant temp sensor or something else going on. This may seem obvious answer but I have to ask, did you fill the car/engine back up with coolant? Just have to ask since I've had them not start at all only due to no coolant being in the system. |
Hi Nate,
Dennis form Harrisburg here. I'm definitely not a trained ear. Would it crank normally with bad timing? Only after letting it sit, it "runs" for 1-2 seconds before cutting out and sounds "normal" for that small time period, then on;y cranks. I wouldn't have thought of a coolant temp sensor. Where is it and how do I test it? There is coolant in the radiator at least. I don't know how much is in the engine. I'm sure I can figure out how to do the timing but I'm staring to run out of time. I normally work 12 hrs per day and the car is sitting in the collision shop's garage. They've been very patient so far. By the way, check your PM re: the body parts. Thanks again Quote:
Update! I tried the temp sensor but wasn't it. Finally checked the timing and it was way off. Apparently it jumped during the accident. Replaced the timing belt and it runs now! Now on to finishing the body work and getting it back on the road! Thanks for the help everyone.
Ticking,ticking ticking! Picked up the SVX from the Auto Body shop (they did great work, looks brand new), but it's ticking....damn! I noticed it after the timing belt was replaced but it only ran for a minute back then. While it seemed to run smoothly on the way home, it's still ticking. Any ideas? Might it just be a matter of changing the oil and running it after sitting for so long (more than two months)?
Dennis |
