Old 11-23-2012, 07:41 AM
Dominus's Avatar
Dominus Dominus is offline
Homo Sapien Superior
Unhappy My Door Hath Screwed Me
So my driver's side door won't lock. Apparently the automatic door locking actuator (or whatever it is properly called) has broken or seized. The door won't lock, I can't press down or pull up on the inside button, it seems stuck in the middle. This is very annoying.
What is more annoying though is that for some reason this problem is drawing power from the battery and draining it so every time I return to it after a night it is totally dead.
So what I am wondering is; Is there a way to disconnect the automatic door actuator so it won't drain the battery, is there a way to do this so I can just lock the car with the key, and is there instructions anywhere for this.
I would really appreciate some help with this asap. I live in the city and can't leave my car unlocked and of course with it draining the battery constantly I can't drive it without jumping it.
P.S. Is there a fuse I could remove that would deaden the door actuator so it stops draining the battery?
“Veni, Vidi, Vici.”
Old 11-23-2012, 07:47 AM
Dominus's Avatar
Re: My Door Hath Screwed Me
I have the 1992 SVX by the way. Dark Teal
“Veni, Vidi, Vici.”
Old 11-23-2012, 12:36 PM
FM977 FM977 is offline
Yes, there is a fuse in the box under the dash on the driver's side. Once the fuse blows the actuator will seize. Replace the fuse and you should be good to go. I just had the same problem.
Old 11-23-2012, 12:46 PM
Dominus's Avatar
What kind of fuse do I need to get to replace it?
“Veni, Vidi, Vici.”
Old 11-23-2012, 12:50 PM
I pulled my fuse to deactivate the locks. Try removing the fuse guessing # 13 auto lock
Old 11-23-2012, 02:16 PM
Dominus's Avatar
Was your battery being drained when you had this problem?
I'm going to have to jump this car just to test this out. What a pain.
“Veni, Vidi, Vici.”
Old 11-23-2012, 02:58 PM
In the short term just disconnect the negative battery terminal.
Old 11-24-2012, 07:25 AM
dcarrb dcarrb is offline
If the fuse were blown it wouldn't be draining the battery.
dcb
Old 11-24-2012, 09:18 AM
Dominus's Avatar
Yes, It doesn't seem like it was the fuse. I took it out and it looked brand new. I replaced it anyway, but of course that didn't fix anything.
Can I just removed the fuse to keep it from draining the battery?
“Veni, Vidi, Vici.”
Old 11-24-2012, 09:22 AM
If you pull the fuse it will dissable the solinod and release the lock
Old 11-26-2012, 12:51 PM
Dominus's Avatar
Okay I took the Door Lock fuse out of the box and that released the door locks. So now I can open and lock them using the key.
Unfortunately there still seems to be a power drain that deadens the battery. I even took it out and drove it for like twenty minutes and disconnected the negative cable so it wouldn't be drained, but it still was. The battery seems to be completely and totally dead, it won't turn on lights, radio or anything. The battery though is only a year old and the rest of the system seems fine as it starts right up when jumped.
What do you think? Do I have a power drain somewhere or will this battery simply not hold a charge anymore even though it is only a year old? Should I disconnect the wire to the auto locks?
“Veni, Vidi, Vici.”
Old 11-26-2012, 02:48 PM
Ok I will shoot for 2 in a row. Remove the neg terminal of the battery. Touch the + of you multi meter to the battery - terminal and the - to the removed cable. In the amp position see what the draw is ( be sure your meter will handle 10 amps. ) there should be a slight amp showing. my guess is the trunk light. I had an old cell phone connector draining mine. YOu can start pulling fuses one at a time till the meter drops. Pull the clock fuse 1st.
Old 11-27-2012, 04:40 AM
wdb wdb is offline
dances with roads
Twenty minutes may not have been long enough to recharge a fully dead battery, but it is not a good sign that you disconnected the negative terminal and the battery was still dead when you came back.
Have you put a voltmeter on it?
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 11-27-2012, 01:17 PM
Dominus's Avatar
I took the battery out and charged it overnight. The multimeter said it had 12 volts. I put it back in the car and it started fine.
Thinking I might have a bad fuse I checked all the fuses with a multimeter. They all appeared to be fine.
Do you think the battery was just super dead and perhaps I don't have a drain besides the door actuator which shouldn't be drawing any power with its fuse removed?
“Veni, Vidi, Vici.”
Old 11-27-2012, 02:28 PM
Yea I would bet that the actuator drain just slowly drained down the battery, and then the near-dead battery caused the rest.
