Old 09-24-2012, 07:42 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
My A/C compressor won't ever turn off...
So, I always thought that the A/C compressor was supposed to be off in Econ mode or when the system is off. The clutch for mine is always engaged no matter what setting I have it on or what the temperature is.
Any ideas?
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-24-2012, 08:03 PM
stiguy's Avatar
stiguy stiguy is offline
Re: My A/C compressor won't ever turn off...
Bad relay or short somewhere?
I know when I have switched my cars from r12 to 134a the comp would not cycle on and off when I had the ac on... But for the comp to stay engaged even when in the off position that's strange
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 09-24-2012, 08:09 PM
SVX8588's Avatar
I hadn't thought to check relays. I just have noticed it making it's gurgling noise even when I don't have it turned on.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-24-2012, 09:17 PM
Tapani Tapani is offline
Is the clutch engaged when the engine is not running?
Btw, the stock SVX system will not cycle at all unless a protection limit is reached. The compressor has a variable discharged feature.
Tapani
Old 09-24-2012, 09:54 PM
Tireiron Tireiron is offline
Unplug the connector from the A/C compressor and then start it up and see if is still running. If so the clutch is dead. If not it is an electrical issue somewhere.
Old 09-24-2012, 10:17 PM
Correct. There is a plug, which, if you follow the wire, goes to the very front of the AC compressor near the clutch, that if you unplug will disconnect the power used to activate the AC clutch to grab the pulley. That will determine whether it's an electrical issue or a mechanical one at least.
Old 09-25-2012, 05:17 PM
Tapani
If the AC is on, the clutch is always engaged. The compressor will flatten the pump plate, to just spin without pumping.
Old 09-25-2012, 08:46 PM
SVX8588's Avatar
The clutch is good, so I know its an electrical issue. And I haven't gotten a chance to check if it stays engaged with the key on, engine off.
I'm hoping it's something simple like a stuck relay...
Just gotta find the time to track it down!
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-29-2012, 08:09 PM
SVX8588's Avatar
That was the easiest fix ever.
Here's what I did:
1. Swap relay with high beam relay
2. turn key to "on" and observe high beams stay on with switch in low beam position
3. Pop plastic cover off bad relay
4. use small screwdriver to free stuck contact plate from coil
5. reinstall relay
Tada!
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-29-2012, 08:56 PM
You gotta like that. Free and easy.
Old 10-07-2012, 12:14 AM
stiguy's Avatar
Woohoo simple fixes are the most satisfying!
Old 10-07-2012, 08:21 PM
SVX8588's Avatar
Yep, I'm hoping it'll help my mileage a little too... but not too likely.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
