Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 03-25-2012, 11:48 PM
Green1995SVX's Avatar
WRX Steering Wheel Swap - Horn Wiring
I've installed a WRX steering wheel in my SVX. Could somebody who has done the swap please post the details on the wiring to make the horn work?
Thanks!
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-26-2012, 09:39 AM
Re: WRX Steering Wheel Swap - Horn Wiring
It's very easy. But first, do you intend to (or did you already) swap the airbag charge from the SVX steering wheel?
Old 03-26-2012, 06:31 PM
I intended to, but the mounting points for the charge were different, so I didn't.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 03-29-2012, 11:34 AM
Just a bump. I know somebody must have this knowledge. I'm waiting to get the horn hooked up to get the car inspected so that I can drive it.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 03-29-2012, 12:12 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I swapped the internals of the wheels. It's not that crafty.
Old 03-29-2012, 12:53 PM
Yea, just open up both steering wheels and it will make sense. If you run into problems, then post them up and I'll help out, but it should be fairly obvious once you're looking at it all. Use a SVX wheel that you don't mind sacrificing. I swapped the plug and wiring from the SVX wheel to my legacy one, so it's plug-and-play and I can swap in a stock SVX wheel easily if I wanted to. You will likely have to do a good amount of trimming plastic bits as well. I was also able to swap the cruise controls, by cutting a hole for the stalk (there was already an outline of where the hole would be cut), and mounting it to the existing mounting points that were already in the wheel. I looked through my pictures and I didn't find anything useful from when I did it, sry.
Old 03-29-2012, 02:08 PM
I already have the wrx wheel installed in my svx, and the cruise is working. All I need to know is how to hook up the horn.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 03-29-2012, 02:38 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Is there anyway you can post a pic or 2 I thought its a direct swap to JDM legacy steering wheel( just the charge part) unless your WRX is USDM?
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 03-29-2012, 06:24 PM
The horn button is connected to the Green/blue wire that feeds the cruise control paddles.
Old 03-29-2012, 07:37 PM
Here's a pic!
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 03-29-2012, 07:49 PM
Is this your prestine 92?!?!?!??!
Old 03-29-2012, 09:54 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
That wheel looks huge..
Old 03-30-2012, 06:22 AM
LetItSnow's Avatar
This. The circuit is completed through the spring-loaded bits that the airbag mounts to. The GB wire needs to clip to the right side airbag mount.
