Old 07-23-2009, 09:09 PM
Joe Joe is offline
[B] Please Help Speedometer Accuracy[/B]
When the transmission assembly is swapped from a legacy with 4.444 gears into a svx with 3.54 gears, is the speedometer accurate, and if so what component swap makes it so.
Old 07-23-2009, 09:27 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: [B] Please Help Speedometer Accuracy[/B]
Iirc, use the SVX's stock speed sensor and tire diameter, and you should be good to go, as the speed is taken from the front axle's rotation and at no point before that.
Old 07-23-2009, 10:02 PM
nexus_7 nexus_7 is offline
my 4.44 changed my mph up about by about 4. so if it says 55 I am actually doing 51.
Old 07-23-2009, 10:39 PM
Joe Joe is offline
Thanks for the replies, I apreciate the correct information. I also agree that the speedometer will be correct.
Now I am wondering how this affects the application of the transfer clutch, since the speed of the rear end is taken prior to the reduction in the gears.
Old 07-24-2009, 11:54 AM
As long as the tires are the same actual size front to back your transfer clutches will be fine.
Note;
Once again, the speedometer will read 5.5% higher than actual vehicle speed due to the disparity of tire sizes between the doner cars tire size, and the SVX's tire size.s
Old 07-24-2009, 03:20 PM
LetItSnow's Avatar
I thought the Legacy (not Outback), Impreza, and SVX shared the same diameter (barring very modern 17s and very ancient 14s)?
Old 07-24-2009, 04:01 PM
Rob, most 4.44 swaps use the trans from a 96-early 1998 legacy Outback that came with a 205/70/15 tire that is 26.30" tall.
The 225/50/16 tire that the SVX uses is 24.86" tall.
