Old 06-14-2009, 07:51 PM
Sanosuke's Avatar
Sanosuke Sanosuke is offline
Found a lost SVX
Oil Pan Replacement
While changing the oil on my SVX I noticed two problems which I feel I need to take car of as soon as possible.
First off there is a small leak from the valve cover where it meets the head. What is the gasket for this piece? RTV?
Noticed how rusty my oil pan is and tapped on it to listen for soft spots and found some. I want to replace it and in fact already ordered the pan. Do yall know a place I can print out the procedures and or know exactly what has to be done, I assume the subframe wants to come out first. Whats the gasket on the oil pan to block? RTV, Thats what the dealership says... just want to make sure.
:..Miharu..:(1994) Laguna Blue SVX 170k. MODs: Beat to shjt.
:..Fey..:2005 World Rally Blue Impreza WRX 80k and rising. MODs: Lowering springs, 22mm sway bars. SS brake lines.
Old 06-14-2009, 08:31 PM
Re: Oil Pan Replacement
There are rubber seals under the valve covers. It's common for them to develop leaks after a bunch of years.
As for the oil pan, despite what I was told I discovered that it's completely possible to change it without removing any other parts, although taking of the plastic under-tray makes life easier. With a 1/4" swivel joint and 10mm short socket you can get to the rear bolts above the subframe. The pan is RTV'd in place, so pull down the old pan, clean the bottom of the block, and silicon up your new one.
Old 06-14-2009, 08:55 PM
Green1995SVX's Avatar
A rusty oil pan in AZ? Now I've heard EVERYTHING!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 06-14-2009, 10:40 PM
Sanosuke's Avatar
Found a lost SVX
Thanks, I was going to try that first anyway I just wanted to double check what was going on with this beast. Anyone know where to get the rubber seals for the valve cover? The reason I assumed it was RTV on the valve cover was there seems to be some where the leak is...
Its a rusty oil pan in Az that I shipped from Pa!!!! Gottcha!!!!!! This car spent around 14 years in Pennsylvania, bought and kept there, driven everyday (rain or sleet) until I bought it and moved out here for school.
Old 06-14-2009, 10:58 PM
valve cover gaskets can be had from the dealership or any of the online sites-subaruparts.com, etc
Old 06-16-2009, 06:43 PM
Sanosuke's Avatar
Found a lost SVX
Thanks for the help one last question which I will ask as I try and look it up.
Is there a torque on the oil pan bolts, I assume its around 20 ft.lbs
Old 06-16-2009, 08:31 PM
Ummm....reasonably tight? I'd measure it as one small grunt each.
Old 06-17-2009, 10:00 PM
Sanosuke's Avatar
Found a lost SVX
Thats pro. Its called the calibrated elbow right?
Old 06-18-2009, 01:49 AM
This post will guide you through the process, thanks to Seth.
http://www.subaru-svx.net/forum/show...+covers+gasket
Old 06-18-2009, 04:50 PM
Something like that.
