Old 05-25-2009, 10:11 PM
Gamesy's Avatar
Gamesy Gamesy is offline
double up the flexplate
since so many people are having issues with flexplates since they keep breaking couldn't you just double up 2 flexplates since they are so thin. then for spacing due to the TC and bellhousing just put a shim there? and voila! thicker plate
Old 05-25-2009, 10:19 PM
Re: double up the flexplate
Or just replace it with a thicker and stronger phaseII 4eat flex plate....
Old 05-26-2009, 12:23 AM
Gamesy's Avatar
i wish i knew that existed b4 i picked up my oem from subaru, where do you get one of those from?
Old 05-26-2009, 05:31 AM
dcarrb dcarrb is offline
I've always figured flexplate cracking to be a maybe-once-in-the-life-of-the-car failure. Is it a recurring problem that warrants preventive measures?
dcb
Old 05-26-2009, 09:02 PM
dcb
SVXride had a string of bad luck with those... I think he lost at least 2 in the same car.
Any 4eat 99+ should work
Old 05-26-2009, 11:34 PM
Gamesy's Avatar
any 4eat 99+ flexplates or trannys? i thought only 98 and earlier only worked on the car
Old 05-27-2009, 06:04 PM
Exactly, which is why you want a 99+ flexplate from one of the trannies that doesn't work (easily) with the SVX.
