Old 05-15-2009, 09:14 AM
longassname's Avatar
Just some dude.
Significant Technical Input
Re: What kind of transmission cooler should I get?
You might want to check your fluid level and make sure it isn't a little high. You really shouldn't be getting up into the 200's. I know Jon has a pwr radiator and uses it's atf cooler with one of my transmissions and I think they said it was running in the 160's.
Originally Posted by immortal_suby View Post
Pretty close. I see about 200-210 in traffic and it cools down to about 190 once I get the TC locked for a little while.
Unlike my previous setup, it now doesn't seem to continue down below the 180-190 range once it gets there.
With the 2 separate coolers and radiator heater bypassed it would cool back down below that.
But I haven't done any long highway runs yet to see if continued driving in hot weather would cool it down more.
Old 05-17-2009, 08:17 AM
immortal_suby's Avatar
Thread Killah
Thanks for the tip! I'll check it today. It's so hard to get a good reading.
Locker Link
2015 BRZ Limited 6MT
Old 05-20-2009, 02:12 PM
Originally Posted by SVXalter View Post
Hey I'm looking into getting an SVX and want to put a transmission cooler on as soon as I get it.
What are your recommendations as for what is best??
I just instaled a Hayden/Imperial #242016 in a members pristine 53,000 mile, absolutely stock SVX.
Before I installed his cooler I went on a road testup a mountain, about an 8° incline on a 53°f day cruising at 55-65 mph.
The peak temp was 207°f, and averaged 188-190°f.
After removing the stock in radiator cooler and installing the Imperial, the peak was 194°f, with the average being about 169°f.
Buy the way,IT WAS 76-77°F outside.
So, 23-24 ° hotter, and the trans was 13° cooler!
The temp dropped to the "normal" 169° much quicker as well.
I put the cooler between the AC condencer and the rad.
The cooler size is 3/4" thick, 7,1/2" high, 15,7/8" long, with a core length of 12,1/8".
