Old 12-04-2011, 10:13 AM
Jekky Jekky is offline
Exclamation Promblem with coolant system!
Dear forum visitors!
Problem: overheating of the cooling system. and flowing antifreeze.
I briefly describe my problem. I have a problem with the cooling system. I must say, that the radiator is in good order. The main pipes, too. More precisely, those connections, that are visible from the outside. The essence of the problem will try to explain step by step:
1) starting a car and warmed it.
2) When the temperature sensor is close to normal (1 / 2 of scale), from under the engine starts to go easy steam generated by antifreeze that dripping on hot items.
3) After driving a car, under the engine appears much steam. Also under the top cover of the engine accumulate a significant amount of antifreeze (see the photo)
4) Anti-freeze drips on the wall of the motor housing where it evaporates.
Feature: when you squeeze tube that enters the radiator, ie, to create pressure, the anti-freeze stream is greatly enhanced.
Tell me please:
cause a leak of antifreeze can be due to rupture of pipe somewhere (although it is not clear whether there are connections in the engine) or it is a problem in the engine (cracked something.)
P.S.
Sorry for bad english. I can try describe the problem more detail by asking your questions
Аlso attach a picture with notes!
Old 12-04-2011, 10:31 AM
Shamus McFeeley Shamus McFeeley is offline
Re: Promblem with coolant system!
removed by user
Old 12-04-2011, 11:51 AM
Originally Posted by Shamus McFeeley View Post
It sounds like your leak is coming from the coolant crossover pipe that is located underneath the intake.
(translation below for a little more clarity)
Pokhozhe, vash utechka idet iztruby okhlazhdayushchyeĭ zhidkosti krossovera, kotoryĭ nakhodit·sya podpotreblenie.
if its that short hose thats there i had that literally explode on me one day
was a real pian to change without removing the intake but eventually got it changed (i have big hands )
if it is not flowing out rapidly im guessing there is a small crack or it is not tightened properly
Old 12-04-2011, 12:03 PM
I just had two SVX do the same thing!
The rubber hose on the left side of the engine,
under the intake manifold,
had a VERY small cut (1/8")
If you go to www.subaruparts.com,
Log on,
check out 1992 SVX 4WD,
engine,
Water Pump,
check out part #12
The part # for it is;
807611111
Old 12-04-2011, 12:27 PM
removed by user
Old 12-04-2011, 12:40 PM
$8.32 USD, or 258 RUB, plus shipping
Old 12-04-2011, 01:41 PM
Log on,
engine,
Water Pump,
check out part #12
807611111
i managed to get some straight hose on there with just a slight bit of kink
its been fine since
Old 12-04-2011, 05:14 PM
Thanks, John.
I could not copy and post that.
Old 12-11-2011, 06:21 AM
Thanks a lot!
Indeed, the problem was a crack in the pipe (807611111). Already order it.
Old 12-11-2011, 08:36 AM
рады услышать, КомРад Импортные электонные компоненты!
Old 12-11-2011, 03:46 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Per Google interpreter:
"Please connect me with great Russian woman."
Not!
Gene
Gene and Ben
Old 12-11-2011, 04:26 PM
"Please connect me with A great BIG Russian woman."
Not!
Gene
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOooooooooooooooo oo!
Old 02-11-2015, 08:41 AM
Well I'm about 175 miles from home and had this coolant hose blow out spewing coolant all over the exhaust and making the engine temps rise. I'm at [urgh] Firestone having it changed, I'm nervous about them breaking something under that intake, but hoping for the best. One mechanic seemed to know a good amount about the SVX so maybe it will be ok.
Old 04-21-2015, 09:30 AM
theflystyle's Avatar
After much searching for what I was looking for I came across this thread which was the closest topic. I am trying to find the part # for this cooland hose underneath the intake manifold (passenger side). See the picture for what I am asking for. It has the ?'s in the arrow. I also added the part # 807611111 (the little elbow) in case it helps for anyone in the future.
1994 SVX LSi
2008 Legacy 3.0R
Old 04-21-2015, 10:57 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Ummmmmmmm why is everyone buying OE hoses when you can just buy a foot of Gates coolant hoses at your local auto parts store for cheaper??
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
