Old 10-19-2011, 03:32 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
HID light bulb spacers?
so i bought an HID kit online and tried putting it in but i notice that it seemed impossible to adjust the light to the correct position...if you are sitting in the car it looks like a V of light with the point of the V where the front license plate would be and then it spreads out form there...so after about an hour of trying to adjust i was taking them out with them still on i noticed that if i pull the bulb out a little bit the beams seems to be right where it should be...
so are there any kind of bulb spacers you can buy or does anyone here have some?
Jared
1992 dark teal SVX LS
Old 10-19-2011, 04:23 PM
Re: HID light bulb spacers?
Are the rubber O-rings on your old bulb and your new HID bulb the same size?
Peel it off the old bulb and add it to the new HID bulb, sliding it down as far as you can. Should help to hold it out further.
See photos here for reference only
http://www.8thcivic.com/forums/light...isibility.html
Never seen this problem before. What brand of kit? High-quality bulbs fit exactly like OEM. My Lavalux kits were $199.00 each.
Old 10-19-2011, 04:32 PM
im not sure of the brand ill look when i get home and get back to you right now i just have some crappy bulbs in there...i did a and found a company that has bulb spacers but not for our bulb type
ill try the O ring thing too
Jared
Old 10-19-2011, 04:46 PM
Did you order 9005s, or 9006s?
Our low beams are 9006s.
PS check the tags on the bulb wiring to see what you actually recieved.
Old 10-19-2011, 04:49 PM
9006s...ok ill let you know about both
Jared
Old 10-19-2011, 06:24 PM
son of b!tch i didnt even notice until just now but you have to really look for it...they say H1 on them the box says 9006 but on the bulb itself very tiny letters says "H1"...the box doesnt say a brand unless "RS type" is a brand
i cant even return them...they got me good
Jared
Old 10-19-2011, 06:35 PM
H1 bulbs should not even fit; they are a totally different socket.
Our 9006 bulbs are considered HB4 bulbs. Look very closely at the bottom of your headlights, it is cast into the lens, under the projector.
Old 10-19-2011, 06:38 PM
michael's Avatar
michael michael is offline
What Potholes ???
How much do you want for them?
Wanted: Steering Wheel
Old 10-19-2011, 06:47 PM
michael's Avatar
What Potholes ???
Are they plug n play, svx connector to H1?
Old 10-19-2011, 06:51 PM
What it looks like he did is glue an H1 bulb into a 9006 socket or something because on the top next to the bulb it says H1 but under it on the little tabs it says 9006 on 1 and then 2 on the other
Jared
Old 10-19-2011, 06:58 PM
michael's Avatar
What Potholes ???
Old 10-19-2011, 07:02 PM
Yes they are
Jared
Old 10-19-2011, 07:08 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
I have a set of Xentec H4 9003 6000k Brand New in box. $45 shipped
1995 POLO LSI 76K MILES SOLD
Old 10-19-2011, 08:50 PM
What are you going to use the H1's for?
Low beams are HB4 (9006)
High beams are HB3 (9005)'
Fog lights are H-3
I don't believe the H1 and H3 bulbs are interchangeable. the electrical connection is different.
Old 10-19-2011, 08:56 PM
What are the brightest FOG I can get. ( I have 85 watt ) Can you have HIV high beams also?I have 6000K lows. High are 100 watt halogen
Sorry the HIV goes in your arm the HID bulb is what I have .
