Old 11-16-2008, 06:16 PM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
ABS problems new axles ???
Ok having problems with the ABS. Just as I am coming to a stop the abs kicks in and the ABS system kicks back with about 2-3 seconds of pulsations. According to my mechanic, it's likely one of two things, ABS sensor or a small crack in a surface that the ABS reads off of (or something like that). If it is the latter, the mechanic says that the axle(s) will have to be changed. I have been told by the Subaru dealership (different mechanic) that my boots need to be changed. My question is when I change the axles I guess I should change the boots. Does it make any sense to have any other related work done at the same time. And, if I need axles, where is the best place to order them?
Thanks for any help and suggestions.
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 11-17-2008, 04:46 AM
dcarrb dcarrb is offline
Re: ABS problems new axles ???
If the ABS "tone wheel" is cracked, this has nothing to do with the axles. Nothing about the axles has anything to do with the ABS, for that matter. But you might as well have all the work done at the same time. Tone wheels are pricey; be sure that's what you need.
If the CV joint boots need to be replaced, the joints themselves probably aren't far behind. Replace the entire axle unit. You can get remans at any auto parts retailer, and they come with the protective boots in place.
There's a diagnostic procedure for checking the ABS electronics; I'd search for that, for starters.
dcb
Old 11-17-2008, 05:15 AM
The tone rings on newer Soobs are on the axle themselves, that may be where the mechanic's confusion comes in??
If you can't find axle's locally, get a hold of Tom (www.svxfiles.com) he sells new, not rebuilt for about $80.
Old 11-17-2008, 07:58 AM
Subie59's Avatar
94 SVX LSI Teal
Yes tone rings are the things I may need. Do they not come on the axles. That's what the mechanic thought. He said he did not think he could find tone rings separately. Are they available separately or do you need the whole axle?
thanks
94 SVX LSI
Old 11-17-2008, 09:02 AM
thanks
On the SVX they are separate. And expensive. Run the ABS diagnostic and get a second opinion.
Again, if you need CV joint boots, you might as well go ahead and replace the axle assemblies. But this has nothing to do with your ABS issue.
dcb
Old 11-17-2008, 04:34 PM
Subie59's Avatar
94 SVX LSI Teal
Thanks guys when you say expensive how expensive are we talking. I'll just pull the ABS fuse if it's too expensive. I think I can certainly live without ABS.
94 SVX LSI
Old 11-18-2008, 04:36 AM
I've forgotten the cost of tone wheels... $150-ish each, I believe. As I suggested before, be sure that's what you need.
I believe it's a bad idea to disable the ABS.
dcb
Old 11-18-2008, 08:29 AM
Tone wheels are cast pieces of metal.
They have no moving parts.
They just spin with the rotation of the wheel.
If they were broken, or missing, then they could be your problem.
However, it's much more likely that it is your sensors.
Our SVXi have a VERY cool self check system.
It will tell you which sensor is bad.
(If it is a sensor.)
Earthworms site has a how to.
http://svx-iw.com/
Go to his site.
Go to SVXIpedia.
Go to checking error codes.
Go to how to check ABS error codes.
Old 11-18-2008, 02:24 PM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
http://svx-iw.com/
Go to his site.
Go to SVXIpedia.
Just curious, will these procedures work for checking the codes on an OBDII car (besides the ECU codes of course)?
Old 11-18-2008, 03:39 PM
Speedklix's Avatar
Locker Link Solution
The mechanic may be assuming they are on the axles as well if his aftermarket supplier does not list it.... which is very likley in this case. I would, for the same reason i doubt there is much demand for tone rings, recommend a sensor check as well.
The statements your mechanic is making in this case are no cause of concern over his ability or honesty BTW, he is just not familiar with the svx.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-20-2008, 10:08 PM
Subie59's Avatar
94 SVX LSI Teal
Just an update on the ABS problem. Turns out it was the ABS sensor not tone ring. The sensor wasn't cheap. Anyway I got the car back, new sensor on right wheel, new CV boots and installed winter tires all for just under $1000.00 Cdn. So just over $10.00 US for you Americans
94 SVX LSI
