Old 04-15-2009, 08:41 AM
BDSDC BDSDC is offline
AC Leak...Where to look?
Replaced compressor, worked fine, with new oil and light charge. After a couple of days, no pressure. I'm going to change O rings and try again. Any advice is welcome. Where to look? Should I use leak stop?
Old 04-15-2009, 08:46 AM
NiftySVX NiftySVX is offline
Re: AC Leak...Where to look?
Always replace any disturbed o rings. Never use any kind of leak stop on any fluid system, you'll do more harm than good. The most common a/c leak that I see in the shop is from a condensor that got hit by a rock.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 04-15-2009, 09:20 AM
Mine was leaking where the line comes into the condenser in the lower right corner. My solution was to ignore it and never use the A/C system. It will be coming out this summer.
Old 04-15-2009, 09:31 AM
Green1995SVX's Avatar
I've seen a bunch of svxs leak where the lower line comes into the condensor. I'd start there.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-15-2009, 11:27 AM
I've had the high pressure hose from the compressor to the condinsor (the one by the battery) go bad, and start leaking through the rubber part of the hose....
Old 04-15-2009, 01:03 PM
dcarrb dcarrb is offline
Same here... saw little beads of oil weeping right through the hose. But that was a slow leak.
Also had the worked-for-a-day-after-replacing-the-compressor thing happen, and it was the O-rings.
dcb
Old 04-15-2009, 04:20 PM
I had a leak that took two years to find. Bottom right hand corner of the Condenser.
Must be a mounting fault.
Old 04-15-2009, 06:54 PM
redlightningsvx's Avatar
Collision Refinishing Tech
My high pressure hose leaks were its bolted on top of the compressor were the metal line is welded to the bolt on end.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-21-2009, 08:43 AM
Wink Re: AC Leak...Where to look?
Thanks to everyone for the help. So far in 5 months of ownership I've fixed major problems...power steering leak, overflowing and AC leak for less than
2 bucks... Any other O Rings I should look to replace?
Too bad trans didn't fix so easy...
"Got a low maintenance women and a high maintenance car." http://www.subaru-svx.net/forum/imag...es/leright.gif
