Old 08-22-2011, 09:25 PM
92 SVX 92 SVX is offline
Re: stumbling idle and backfiring, PLEASE HELP!!!!!
Originally Posted by 92_LSL View Post
I wish I had a 5 speed!!!!!
It's a temporary fwd legacy swap until I can afford a five or six speed swap. Could the starter ground contribute to this kind of behavior?
oh, not 5sp, hmm should check that then it could be serious does it check the same way the svx stock trans does?
any bad ground can contribute. As Harvey said
If the engine block is not grounded to the body, spurious voltages can return to the body through the signal wiring carrying control information to the ECU, to change the signals.
Old 08-22-2011, 09:29 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
Can someone get me a picture of the ground on the dog bone?
I has teh FWD LS-L
Old 08-23-2011, 02:00 PM
92_LSL's Avatar
So I checked the grounds and they're all connected. What next?
I has teh FWD LS-L
Old 08-23-2011, 04:43 PM
how did your plugs look? were any of them different than the rest? this can narrow down your search to specific cylinders or problems. for example plugs with a pinkish color on the electrode means you have too many additives in your gas, yellow too much sulphur, etc...
Old 08-24-2011, 01:17 PM
92_LSL's Avatar
Now my battery isn't charging, alternator.......
I has teh FWD LS-L
Maybe the battery just took a s*** from sitting for too long unused.
Old 08-24-2011, 01:21 PM
92_LSL's Avatar
Hopefully, I got it charged at autozone and they said it was good though.
I has teh FWD LS-L
Old 08-24-2011, 07:51 PM
steveherman steveherman is offline
mine is running alot better.
maybe u should try the ethanol free gas in st cloud.
that is what i did.
that and gonna replace fuel flter.
Old 08-24-2011, 10:09 PM
I'll be there personally to help you figure it out if you haven't by then in about 2 and a half weeks or so...
Old 08-25-2011, 02:03 PM
92_LSL's Avatar
Are you referring to me?
I has teh FWD LS-L
Old 08-25-2011, 02:07 PM
92_LSL's Avatar
The battery was completely done, luckily it was still under warranty. It also cleared up the idle a little, although the improvement is barely noticeable.
I has teh FWD LS-L
Old 08-25-2011, 07:49 PM
of course man. I'll be in Florida and can try and give ya a hand
Old 08-27-2011, 11:46 AM
Tapani Tapani is offline
I seriously recommend to get something like the ECUtuner - you can see most of the critical readings in real time while you drive (have a friend with you to work the lap top).
Takes a lot of the guess work out if you know what's going on.
Tapani
Old 08-29-2011, 05:16 PM
92_LSL's Avatar
When are you coming?
I has teh FWD LS-L
Old 08-29-2011, 05:39 PM
92_LSL's Avatar
Also, I unplugged the O2 sensors today and it didn't run any worse or better, nor did it throw a check engine light. WTF?????
I has teh FWD LS-L
