Cam seal replacement
Can the cam seals be replaced without removing the motor?
Re: Cam seal replacement
Absolutely, but you do have to remove the timing belt and cam pulleys to do it. Good opportunity to do the crank seal and valve cover gaskets while you're in there.
Fairly complex for a novice...are you asking because you heard/had a shop tell you this ?
No,
I'm a pretty good mechanic but was trying to decide how much of a project I was getting into. Good to know this is going to be easier than I was thinking. Thanks for the input. |
http://www.phantomotaku.com/SVX/MSA5TCD95S_8_Engine.pdf
You might find this link helpful...Good Luck with the job. BTW, if you are so inclined, would love to see it written up with pictures !!! Last edited by fasteract7; 10-23-2015 at 01:59 PM. |
Thanks for the link.
A write up and pictures would be nice. Not one of my strong suits but I will see how it goes once I get started. |
