Old 06-06-2004, 07:28 AM
The Monzta's Avatar
The Monzta The Monzta is offline
'Check Engine' Warning Lamp
Every now and again, the 'Check Engine' warning light comes on whilst I'm driving. I stays on for no longer than a second and then it may not happen again for a few days. I take it if I actually had an engine problem the light would stay illuminated?
Any idea what the problem could be?
The Monzta
'96 Subaru SVX (111K) - UK spec
'85 Opel Monza GSE (71K)
'86 Opel Monza GSE (95K)
'93 Toyota Estima Lucida (37K) - JDM import
My psychiatrist says I'm suffering from paranoia........but he's always hated me!!!
Old 06-06-2004, 07:50 AM
pottsy
Does the light come on in the rain or when the car is wet? My light comes on for a very short while whenever I take the car through a car wash! Either its the high pressure water affecting the wiring or its sensing water ingress into the engine air filter/up exhaust. Either way the light goes out pretty quickly. If its anything like mine, its probably nothing to worry about.
Thanks for the recommendation over Protechnical - took my car there and they were great.
Pottsy
Old 06-06-2004, 06:20 PM
The Monzta's Avatar
Pottsy
Hi Pottsy,
The light just comes on of its own accord mate. At first I thought it was only when I did sharp right-handers (roundabouts etc) but it comes on willy-nilly in any weather condition.
Glad you found Protechnical useful, bloody handy with you living in the same town as them eh?
The Monzta
Old 06-07-2004, 01:32 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Hi Monzta,
We've had the "Check Wallet" light a few times. The dealer said that it means that one of the sensors has returned a reading outside of the expected normal range. If the light does not stay on then you can ignore it.
You can get the ECU to tell you what sensor is causing the error by using the blue wire trick described elsewhere on this site.
Phil.
Old 06-07-2004, 05:53 AM
The Monzta's Avatar
Thanks for that Phil. It's a relief to know by engine isn't about to go Kaboom in acloud of smoke and twenty pound notes. My mechanic has all the diagnostic kit to plug into the car so I'll ask him to check it out when I next see him.
The Monzta
Old 06-07-2004, 06:03 AM
Timbo
Montza, Phil's right. It usually just means that one of the sensors has jigged a little out of spec and doesn't mean it'll cost you heaps. It is important though to have the diagnostics run occasionally and the codes cleared regularly as they build up over time and can cause problems of their own if things get a little cramped in the black box.
Good luck,
Tim
Old 06-07-2004, 01:59 PM
The Monzta's Avatar
Thanks for that Tim, I'll give my man a call and book the car in for some jobs that need doing and while he's got it I'll get him to check the codes and then clear them. He checked them last time I left the car with him and it showed a lambda sensor trigger. He told me to stop being a skinflint and change to super unleaded.......I did and the problem went away.
The Monzta
Old 06-30-2004, 01:33 PM
The Monzta's Avatar
OK guys, ' Check Engine' light is now staying on anywhere between five seconds and two minutes at a time. Still no rhyme or reason that I can see as to why it should be coming on, it's just intermittent. Some days it doesn't come on at all and others it's on and off all day. Today though has been the worst coming on for protracted periods when both moving along and sitting in traffic. I've checked all fluid levels and listened for any strange noises, but nothing seems out of order. Should I be going into panic mode right about now?
The Monzta
Old 06-30-2004, 05:36 PM
Smile Believe the psychiatrist!
I would not panic for now...... But maybe in 5 minutes or so..
Seriously Monzta, you can't ignore it if it's coming on more. Probably means one of your sensors, or more than one, is sending "funny" signals. Or broken.
Like Phil says, do the blue wire thingy. Full instructions here:
http://www.subaru-svx.net/photos/user.php?How-To|14264
under the first file on code instructions.
Read the two pages, you can easily do it yourself without waiting on your mechanic.
Old 07-01-2004, 10:37 AM
The Monzta's Avatar
Thanks for that Joe, except when I clicked on your link to the 'diagnostic codes/blinking lights' folder it was empty.
Is this info held anywhere else on the site?
The Monzta
Old 07-01-2004, 10:52 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Try here
http://www.subaru-svx.net/photos/files/How-To/14337.doc
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 07-01-2004, 10:57 AM
Smile No Word yet?
No Monzta
Those files are not empty. It's just that all of them except the last one are Word documents. You using a Mac or something? Have you got Microsoft emulation software?
If you click on the link again, then click on Engine, then click on Codes, the last file, list of Engine Codes is a bitmap, .bmp, it's laboriously big on my slow system, but you should be able to read all the codes from it. [remember to enlarge it!]
I will cut and paste the text from the ones you want in the next couple of posts, OK?
Old 07-01-2004, 11:00 AM
Check Codes instruction, non-Word
Check Engine Code Instructions
Directions for checking the Codes
1) Remove the kick panel just beside the left foot rest on the driver's side.
2) Locate blue wires.
3) Locate black connector. Hold it notch up.
4) With ignition off, insert one of the wires into top row, 2nd pin from left.
5) Turn key to on position, but do not start the car.
6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching blinky light until you get mesmorized.
so far so good
Old 07-01-2004, 11:02 AM
Clearing Codes, non Word
To clear codes (after problem has been resolved):
1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the
black connector, with notch facing up.
2) Start car. Shut off car. Remove pins.
3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals.
and still, so far so good
Old 07-01-2004, 11:05 AM
Subaru Code identification, non Word
CODE PROBABLE CAUSE
11 Crank Angle Sensor or Circuit
12 Starter Switch or Circuit
13 Cam Position Sensor or Circuit (TDC Sensor on Justy)
14 Fuel Injector No. 1 (Legacy, Impreza, Justy, SVX)
14 Fuel Injector No. 1 and 2 (XT, Loyale, GL, DL)
15 Fuel Injector No. 2 (Legacy, Impreza, Justy, SVX)
15 Fuel Injector No. 3 and 4 (Loyale, GL, DL)
15 Fuel Injector No. 5 and 6 (XT-6)
16 Fuel Injector No. 3 (Legacy, Impreza, Justy, SVX)
16 Fuel Injector No. 3 and 4 (XT)
17 Fuel Injector No. 4 (Legacy, Impreza, SVX)
17 Fuel injector No. 1 and 2 (XT-6)
18 Fuel Injector No. 5 (SVX)
19 Fuel Injector No. 6 (SVX)
21 Coolant Temperature Sensor or Circuit
22 Knock Sensor or Circuit (Right Side on SVX)
23 Air Flow Meter or Circuit (Exc. Justy)
23 Pressure Sensor (Justy)
24 Air Control Valve or Circuit (Exc. Justy)
24 Idle Speed Control Solenoid Valve (Justy)
25 Fuel injector No. 3 and 4 (XT-6)
26 Air Temperature Sensor (Justy)
28 Knock Sensor No. 2 (SVX, Left Side)
29 Crank Angle Sensor (SVX, No. 2)
31 Throttle Position Sensor or Circuit
32 Oxygen Sensor or Circuit (No. 1, Right Side, On SVX)
33 Vehicle Speed Sensor (VSS) or Circuit
34 EGR Solenoid or Circuit
35 Purge Control Solenoid or Circuit
36 Air Suction Solenoid Valve (Impreza)
36 Ignitor Circuit (Justy)
37 Oxygen Sensor (No. 2, Left Side, On SVX)
38 Engine Torque Control (SVX)
41 Air/Fuel Adaptive Control
42 Idle Switch or Circuit
43 Throttle Switch (Justy)
44 Wastegate Duty Solenoid (Turbo Models)
45 Pressure Sensor Duty Solenoid (Turbo Models)
45 Atmospheric Pressure Sensor or Circuit (Non- Turbo Models) 49 Airflow Sensor
51 Neutral Switch (Manual Transmission Models)
51 Inhibitor Switch (Automatic Transmission Models)
52 Parking Brake Switch (Exc. Justy)
52 Clutch Switch (Justy)
55 EGR Temperature Sensor or Circuit
56 EGR System
61 Parking Brake Switch (Loyale)
61 Fuel Tank Pressure Control Solenoid (Impreza)
62 Fuel Temperature Sensor (Impreza)
62 Electric Load Signal (Justy)
63 Fuel Tank Pressure Sensor (Impreza)
63 Blower Fan Switch (Justy)
65 Vacuum Pressure Sensor
and on we go...
