improving shifts... DIY shift kit possibilty?
Ok, so I was looking at the smallcar website at their stage 1 shift kit or whatever they call it. Seems like a good idea and everything. Also, I've heard of folks just unplugging that sensor in front of the battery and that does the same thing, but makes for not the most friendly driving otherwise.
Well, maybe this has been done, maybe not, but here's my idea. Why can't you just cut one of the wires that goes into that sensor thinger and splice in two wires that run into the cabin to a switch. When you want firm shifts, you just flip it (so the circuit is open) and then when you're done you just put it back. That way, the tranny acts normal under "normal" driving, and when you want aggressive shifts, you can have them. Would this even work, does this make sense... Has anyone ELSE done this? Please, if you have information regarding whether or not it will work, please let me know as I'm trying to learn about the car while NOT destroying it. Thanks in advance. peace out homies. -nevin
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
You will need a resistor across the switch, or you will generate unwanted TCU codes...not to mention the dreaded 16 blinks from the Power lamp on startup...
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
The thing beside the battery is a resistor. The specific value of the resistance (the numbers of ohms) governs how firmly the trans shifts. Some people have swapped theirs for different rated resistors to get firmer shifts. Your switch idea could work, but as processengr said you'll need some sort of resistor in there to keep the TCU thinking straight.
I got the kit just hanging around after my 5 speed swap. I'll sell it cheep.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
The dropping resistor has a special function and this does not involve line pressure adjustment. Disconnecting same does increase line pressure, but importantly as a result the designed function is lost. This factor should be carefully considered.
If you go to my locker, you will find information under Transmission Solenoids, which includes details regarding the true function of the dropping resistor circuit.
What is considered a firm shift? Does this mean an increase in power between shifts, fuel increase in between shifts and/or lack of stall time between shifts? There's so much going on in between the shifts that they all seem cumulative to the lag/slow shift. I hate it!
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
I've had my resistor unplugged for quite awhile now, and am generally happy with the shifting performance (much tighter, firmer), don't care that I get 16x POWER at startup, but am loathe to lose selectable 3rd gear to the dreaded hunting/braking effect when cornering back roads and going down hills.
If I don't care about the power light, i wouldn't even have to bother with the resistor, i could just wire up an off/on switch in the cockpit and call it a day, right? any recommendations on what gauge wire or what type of switch I should choose?
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
Refer my previous post. Your questions indicate that you are unaware of exactly what is involved and therefore may not have checked out the data in my locker. If not I strongly advise that you do so.
If you decide to proceed with a switch, I can advise on all that is needed, including how to very simply overcome the indicator light problem. N.B. No responsibility accepted in respect of your transmission. There is an important issue involved in respect of the main line pressure control solenoid.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 10-10-2007 at 04:09 AM. |
Well, in regards to whether or not I'm still considering this... I've just purchased AFBeefcakes old shiftkit. I'd much rather do it the right way than my way if my way isn't exactly right.
THanks again for helpful tips and advice. Cheers! -nevin
well, im humbly stupid. would you mind explaining why this idea is a bad one, in simple terms?
The true reason of the resistor circuit, is to ease the arduous repetitive functions imposed in respect of the main line pressure control solenoid. Disconnecting the resistor eliminates a designed feature and could ultimately result in failing line pressure.
