SVX Diagrams
Does anyone have a 4-view diagram of an SVX? Something like the one below:
The views need to be square (no perspective shots) and the higher resolution the better. I'll be using it to generate a 3D model of the car in CATIA. I have images that should do for the front, rear and side, but nothing for the top view. My main goal is to play around with customized body parts (bumpers, skirts, etc), but over time I can also turn it into more of an engineering model with mechanical bits inside.
Re: SVX Diagrams
Try finding a copy of the Road and Track write up when the SVX first came out. I believe (?) that it had these figures in it.
Cheers, Bill
Re: SVX Diagrams
Bill is correct. This is shown in the road and track guide. I have a copy at my office and I'll try to scan it in tomorrow if I have a chance.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Re: SVX Diagrams
Awesome! That would be a great help. Thanks!
Re: SVX Diagrams
For anyone curious, here are a couple of my current projects:
The first is an R8, the second is a float for my RC plane. The float I'll be turning into a full parts model with all the structural and mechanical bits. The yellow surfaces are only skins with zero thickness, they form the outer shell from which I can build inward to create the internal parts. My roommate just ordered a 3D printer, so in a few weeks I'll be able to design, prototype and test my own parts.
Re: SVX Diagrams
This is all I could find. No dimensions
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-04-2013 at 06:25 AM. |
Re: SVX Diagrams
Looks familiar....
If you get a good 3d model of it that I can use in AutoCad or Inventor, I would love to get a copy of the file....
Re: SVX Diagrams
Sure, I'll definitely make it available to anyone who would like it. I'm working in Catia, so it will be a .catpart format. I'll have to investigate saving into different/universal formats.
Re: SVX Diagrams
Here's a quick update of my R8 project:
Re: SVX Diagrams
Looking good!!!
Re: SVX Diagrams
Small bump. I have 3 of the 4 views I need (side, front and rear) but still need a top view diagram. Anyone know of a source for one? I've been through the factory service manual to no avail.
Re: SVX Diagrams
Stand above an SVX on an overpass & take photos ......
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: SVX Diagrams
lol. My car isn't drivable right now (blown fuel line and broken window), and a picture adds depth to the shot. I need a 2D diagram that keeps all the dimensions accurate.
Re: SVX Diagrams
Crazy whats your e-mail i have all 4 views
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... Last edited by Gamesy; 12-11-2013 at 01:39 PM. |
Re: SVX Diagrams
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
