#1261
Well, I order a G-Tech Pro RR on Saturday. I should have it by Wednesday. I can actually run some tests, this weekend, with the software I still have sitting in my car and let you know the results.
#1262
I used Dan's when he wanted to do some before and after runs w/ his 5speed(still didn't do the afters ) They are really easy to work with and relatively consistant
Tom |
#1263
Ran my Stage III car through inspection today. It passed the emissions test with no troubles.
#1264
Thats sweet it passed emissions. So the q' is, does it do anything? WAY noticable difference i hope>?
Current: 95 svx Ls-L (Black) 91 5sp awd xt6 (red) Had: 91 xt auto awd(lt blue) 85 xt 4wd turbo 5sp(blue/white) 86 xt 2wd turbo 5sp(black) 85 xt 4wd turbo 5sp(silver/white) 89 xt AWD 5sp (white) 85 xt 4wd turbo 5 sp sold to Zukiru (silver) 86 xt turbo 2wd 5sp (silver/black) |
#1265
what do you mean way noticeable?? performance or emissions
Tom |
#1266
Sorry if I'm bombarding you with questions, but I am a certified emission inspector, and I have a professional curiosity to satisfy
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#1267
im not surprised it passed. Mike wrote the software so basically run like a stock car until it was under load. Since most NJinspection stations on have 2wd rollers they test it at a certain rpm under no load.... should pass as easily as any other svxw/ anECUtune chip
Tom |
#1268
#1269
Delaware doesnt have a load system. They test at idle, then have you bring the rpms up to 2500 and hold it there. Here are the results.
HC (PPM) : Low = 105, High = 30 (tolerace = 220 for both) CO (%) : Low = 0.58, High = .46 (tolerace = 1.20 for both) CO% + CO2% : Low = 15.18, High = 15.3 RPM Reading : Low = 681, High = 2477 They also test the fuel tank and cap for leaks. |
#1270
In Ontario, we also test the fuel system integrity as part of the test. You wouldn't believe the number of people that get really mad when I tell them that they need a new gas cap. The only real difference I see is that we measure for NOx in parts per million as well. The NOx limits are usually pretty lenient though. There are also special rules for "hot rods" which you'd think would benefit cars like this, but strangely, this supercharger system wouldn't qualify; the rules only consider the car a hot rod if it has had an engine swap to a configuration that was not available in that model in that year. There is also a loophole that allows cars with a salvage title (brand - rebuilt in Ontario) to have modified limits. Most people assume that the program is nothing more than a cash grab by the government, when, here at least, they make just enough to break even. And for cleaner air, I say it's worth the couple extra bucks every other year.
#1271
I think I read somewhere that Subbies and other AWD vehicles are exempt in some places, due to unavailability of 4-wheels emissions dynos. Only 4-5 more years before the SVX is exempt from e-testing! Unless they changed the 20 year rule.
#1272
The numbers may be a little higher due to my exhaust. I've done away with the entire factory exhaust. I'm using only 2 high flow Magnaflow CATs and run dual pipes all the way back to a flowmaster dual-in/dual-out muffler.
Going from 3 restrictive factory cats to 2 highflow aftermarket cats as got to make some differences, right? |
#1273
In Ontario, there are no testing exemptions based on vehicle type. Cars and trucks with Automaticly engaging 4-wheel drive (like Subarus, GM trucks with ATC 4x4 systems, and a bunch of others) and non-disengageable traction control (Mercedes Benz, some Jags, Porsches, etc), must still be tested, but use the aforementioned two-speed idle test procedure. As far as I know, the 20-year exemption still applies, and similarly, new cars and light duty trucks don't need to be tested until they are 5 years old. Based on what I know about etests now, if you don't like to maintain the emissions controls on your car, don't buy a Cavalier, or any 1990s Mazda with a V6. I apologise for rambling. This is a subject I know fairly well and can go on about at length because I enjoy it, but I know we're getting off topic. Quote:
#1274
good to know Mike, why is your idle so low??? I have mine running close to 1,000 so the blower has no chnace to rattle
Tom |
#1275
