Old 04-24-2009, 06:37 AM
Famouspork Famouspork is offline
blue smoke
I did not pay a lot of money for my car, but it seems I'll have to change many things in it to get a good running car.
Its putting out bluish smoke when cold and at hard acceleration when warm.
Head gasket?
Valve seals?
Rings?
all of these answers?
Old 04-24-2009, 06:47 AM
y2daniel1981's Avatar
y2daniel1981 y2daniel1981 is offline
Re: blue smoke
blue = oil. So any seal that that can get oil into your engine
Old 04-24-2009, 08:15 AM
Re: blue smoke
Where should I look first?Where are svx most vulnerable to seal breakage?
Old 04-24-2009, 09:08 AM
Re: blue smoke
Most keep the oil from getting out of the engine.
Smoke during acceleration is typical of worn piston rings. Smoke during a cold start can be either the rings or the valve seals. A compression test can identify the bad rings.
Old 04-24-2009, 10:29 AM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
Re: blue smoke
Yep. I'd say rings, but do a comp test first.
Old 04-24-2009, 12:21 PM
Re: blue smoke
dagnabit!!!
Old 04-24-2009, 12:51 PM
Re: blue smoke
My Claret exhibited similar symptoms, along with a head gasket issue, so we opted to rebuild.
Old 04-24-2009, 01:00 PM
Re: blue smoke
most probable course of action
Old 04-25-2009, 08:50 AM
subbieatnz's Avatar
Re: blue smoke
Dont spose it is over full with oil? lol I had that problem. dont try filling your svx at nite in the dark with very little light lol
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 04-25-2009, 09:24 AM
bjandtheband's Avatar
bjandtheband bjandtheband is offline
Re: blue smoke
mine did the same thing ,so i got the cam seals and valve cover gaskets replaced and that fixed the problem.
Old 04-25-2009, 10:38 AM
Re: blue smoke
sounds like ring wear to me... As others have said. Comp test to be sure... they are a ***** to do on this engine but may be worthwhile for a proper diagnosis
Old 04-26-2009, 01:00 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: blue smoke
This is from one of my old posts - it might help you with the issue.
Hey guys - had similar problem with mine a few months ago (it would puff grey smoke at initial stat-up only), I checked PCV valve & all the other standard issues... but to no avail, just could not put my finger on the issue.
Took it along to local agent who has always serviced it for pas 10 years (hard to think that I have had it that long!!).
He suggested the Aux. air control valve was blocked or not working (this is a non-serviceable part - yeh right!!!). If you are standing in front of car then the AACV is located under the right inlet bank (header pipes) - look between 1st & second ones you will see a round tapered aluminium tube - it has a square base with 4 bolts attaching it to the block (also has 1 - 2way connector at taper end).
This operates an aux air supply when the engine is cold, operates on a 12 volt supply operating a bi-metal spring (plus the engine getting warm through the aluminium block casting).
When cold the tapered part is fully open, about the size of a NZ 5c piece (dime size) - as the spring & engine warm up then there is a sliding shutter that closes approx 80% off.
Sorry guys but my scanner has died last week - but those of you with 1992 service manuals look at book 2/3, section 2-1 (page 3) Emission control system & vacuum fitting, part 15.
Same drawing is also in section 2-7 (page 3) Fuel injection system, part 15.
Shown fully is in section 2-7 (page 5) AUXILIARY AIR CONTROL VALVE.
Mine was full of oil - he explained that this happens when the car is being used for short stop/start trips.
I got the old one back - soaked it in kero & tested it with 12v supply, works like new (so have a spare!!).
Maybe some one can copy & place in the "how to" area?.
Good luck - from New Zealand.
Old 04-27-2009, 05:05 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
Re: blue smoke
ummm what are these "agents" you NZ types keep talking about?
- John
Old 04-27-2009, 06:09 PM
SURTEESS's Avatar
Cool Re: blue smoke
Local agent (in my case) = local Subaru dealer/service center....
Old 06-17-2018, 11:09 AM
RisingPhoenix RisingPhoenix is offline
Re: blue smoke
Same here. Several mechanics told me the cam seals and Valve Cover Gaskets are quite bad and the main cause of blue smoke at startup. Amongst other gaskets and seals needing replacement.
Rings and pistons rarely have issues unless poor oil is used.
Mine has close to 300,000 miles and it's sensors and vacuum that fail way before the engine has issues.
NOTE: I have no blue smoke while car warms up or under acceleration.
