Old 10-11-2008, 07:43 PM
Driver's Side Door Lock is Stiff
So all of a sudden my drivers side door lock is hard to turn. It catches if you jiggle the key a bit, but it feels stiff when it does turn. Also the key fob doesn't lock or unlock anymore, (nor does it make the beeps). It may just need a new battery but I'm betting the 2 issues are related. It has ben sitting for about a 5 days but worked fine before.
I puffed some graphite in the key hole and it improved, but only a little. Right now it is usable but definitely a pain to lock.
Any suggestions?
Old 10-11-2008, 08:00 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Driver's Side Door Lock is Stiff
I've had success with disassembling and soaking the tumbler in vinegar overnight followed by graphite.
Old 10-11-2008, 08:05 PM
gstape gstape is offline
try pulling the door lock fuse out and putting it back in. I've had success with that before when the door locks were not working.
Old 10-11-2008, 08:20 PM
I'll try that tomorrow. Thanks
Old 10-11-2008, 08:21 PM
I am guessing that you take the tumbler out by removing the interior door panel, is that right?
Old 10-11-2008, 08:55 PM
Manarius's Avatar
Manarius Manarius is offline
Mine were stiff when I got the car last year. A little bit of WD-40 later and my locks were in fine shape.
-Jason
-Obi Wan Kenobi
Old 10-11-2008, 10:54 PM
Quickest way to do it is to take a can of penetrating oil, attach the little plastic tube to the nozzle, stick it into your lock, and spray. Insert key, turn back and forth a whole bunch of times. That should loosen it up pretty well.
Old 10-12-2008, 06:52 AM
I'll give that a try, thanks.
Old 10-12-2008, 07:39 AM
Happiness is an easy fix.
Just a few squirts of penetrating oil and good as new. I must be on a lucky streak lately. Thanks for the input everyone.
