Old 10-18-2005, 11:22 AM
1992SVX 1992SVX is offline
Unhappy bad day yesterday
coming home from school around 10 pm. and there is a big cloud of smoke following the car on 95 south. car starts bucking and i pull over and open the hood find out car has leaked all its engine oil. the car is still sitting on 95 south on shoulder. might go look at it today and get it towed home. the oil pressure light never came on . so i think miy engine is toast
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 10-18-2005, 11:30 AM
pipedream's Avatar
pipedream pipedream is offline
Send a message via AIM to pipedream
ooo man. that is harsh mate. did you change your oil frequently?
it was probably time for an engine rebuild anyway.
ok maybe thats not funny.
Old 10-18-2005, 11:34 AM
kuoh kuoh is offline
Was it white or black smoke? Did you glance at the engine temp gauge at all?
KuoH
Old 10-18-2005, 11:59 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Sorry to hear. Good luck!
2006 Steel Gray WRX TR (sold)
Old 10-18-2005, 12:41 PM
How do you know that all of the engine oil was gone. Are you sure that it was empty? I am sorry to hear that.
Old 10-18-2005, 01:09 PM
damn... that sucks, do let us know what exactly was worng
Old 10-18-2005, 02:49 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
unless the engine locked up, it's not toast yet. I once had a 94L that I've driven around for 3000 miles before I realized that there is no oil in the engine.
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 10-18-2005, 02:59 PM
You had a power steering leak, when automatic trans oil hits a hot exhaust, (like the passenger side cat), it can turn into billowing white smoke...
Here's hoping for the best!
Old 10-18-2005, 09:38 PM
the day before i looked at the oil dipstick and it was fine. i change the oil every 2500-3000 miles. the smoke was coming from under the hood. the temp was alittle below the halfway mark.
went to go look at it today. looked at the dipstick and there no trace of oil on it. poured 6 quarts in it to make it level out fine on the dipstick. i drove to shop my dad knows and left it there. had my friend follow me. car was still bucked every so often. drove it ten miles to the shop. the engine was makeing noise. sounded like tapping. tell u more later when i find out
Stage1 Shift Kit
4.44 gears
Old 10-18-2005, 09:42 PM
yikes, hope this works out for the best
Old 10-19-2005, 07:16 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Prayin' that the worse case scenario turns out to be a slightly noisy lifter/adjuster. Good luck dude, hope it works out.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-19-2005, 07:45 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Good luck with her. If she lost all the oil though it should still be loosing it. Check your oil level again and see if you're overfilled. That isn't good either!!!
Old 10-19-2005, 10:34 AM
but when i parked it at the shop. i checked the oil level and it was still fine. maybe it was just a one day thing
Stage1 Shift Kit
4.44 gears
Old 10-19-2005, 03:33 PM
Don't count on it. If it happened once it WILL happen again.
Old 10-20-2005, 02:28 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
from my experiences compare to other cars, if the svx is not parked on level surfarce, the oil/tranny dipstick will give a quite not-very accurate reading.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
