Old 12-17-2004, 06:09 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally posted by mbtoloczko
This is correct for the 4eat. On 5MTs, the speed sensor is spun by the 3rd/4th driven gear cluster. Not central to the thread, but just wanted to point it out for accuracy.
Thanks!
-Chike
2006 Steel Gray WRX TR (sold)
Old 12-19-2004, 04:59 PM
Speed limiter.
The speed limiter is controlled by the TCU.
The Euro box does not have the no.1 sensor on the front diff, it is in the box along with the no.2 sensor.
The no.1 sensor is on the output shaft at the rear of the box, used to detect road speed.
The no.2 sensor is on the parking gear, that is connected to the front wheels. It is used to do the normal functions, checking for wheel spin, and as a back up to the no.1 for speedo use.
The speed control function is performed through the Torque control, which is held low.
Old 12-20-2004, 04:08 PM
Noir's Avatar
Noir Noir is offline
Originally posted by immortal_suby
aww man! call me next time 2753992
dude you were out hunting in NY.
Old 12-31-2004, 08:34 AM
Chiketkd's Avatar
Update?
What's new with your 4.44 swap Porter?
-Chike
Old 12-31-2004, 10:10 AM
Porter
Re: Update?
-Chike
I've decided to "change gears" pun intended and do a 5 speed conversion.
I'm picking up an older Jetta this weekend to use as a daily driver while I build up the SVX and install a half cage.
Anybody want to buy a 4.444 JDM auto trans to use in an SVX? I know it will work, I just don't have the time to work out the electrical on it. I'm confident that any later VTD TCU will work on it.
$550 takes it! I paid $650.
Hell, how about $650 including the 4.444 R160 rear diff to cannibalize for the ring and pinion.
Old 12-31-2004, 04:02 PM
Subafreak's Avatar
Superbeast
Well now that that silly auto stuff is out of the way......what 5 speed do you plan to use and what are you gonna do to it to keep it from breaking?
Old 12-31-2004, 04:05 PM
Chiketkd's Avatar
The JDM STI 5spds are pretty durable...
-Chike
Old 12-31-2004, 04:47 PM
Subafreak's Avatar
Superbeast
-Chike
Well I've heard good things about the RA gears. I was gonna go with those before I decided on the 6 speed.
Old 12-31-2004, 05:34 PM
Readings comin...
he..he..he..
Old 12-31-2004, 07:06 PM
Porter
2001 or 2002 Forester 5MT. It's 4.11 and slightly tougher in design than the Impreza transmissions. I believe the 1st and 2nd gear are different.
I may also look around for an '04 Forester XT transmission. 4.444 w/ significantly reinforced casing and tougher gears sounds like a good way to go.
Old 12-31-2004, 08:31 PM
Chiketkd's Avatar
The Forester 5MT's are a bit stronger from what I've heard as well. What kind of $$$ would one out of an '01/'02 go for?
With a 4.11 Legacy rear diff in place, if I ever go the route of a 5MT swap, this would be the USDM trans I'd get.
-Chike
Old 12-31-2004, 11:32 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally posted by svxfiles
Readings comin...
he..he..he..
(pssst, Tom......pssst, Tom....you did see Jesse's NOS install pics, didn't you.... )
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-01-2005, 05:03 AM
-Bill
DOH!
Old 02-26-2005, 03:09 PM
NeedForSpeed NeedForSpeed is offline
Re: Re: Update?
Porter, did anyone take you up on this?
You said the gears were different than US 4.44, what are they?
Hey svxfiles, here is your new 4.44!
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 02-26-2005, 07:41 PM
CigarJohnny's Avatar
-Chike
I'm curious about the price of that as well. The tranny in mine will need replacing in another year or so if I baby it but will need to be done sooner than later. Not sure if I could live with 4.44 gears but with a smooth clutch and all the slack taken out of the drive train I just might be able to live with it.
Johnny
