Old 04-30-2003, 06:09 AM
gotsubarus gotsubarus is offline
Send a message via Yahoo to gotsubarus
changing ratio
If i were to change the gear ratio to a 4.11 will the rear differential bolt up out of a Legacy?
The problem is the teeth got chewed up on my front differential. I have a cpl of trans out of Legacys that have good differentials.
Old 04-30-2003, 06:40 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: changing ratio
The problem is the teeth got chewed up on my front differential. I have a cpl of trans out of Legacy's that have good differentials.
It should bolt up, however, you will lose the limited slip. What most people have done is to swap the 4.11 gears from the Legacy rear diff into the SVX rear diff so you have the 4.11 gears and limited slip.
It would be a great time to change out your differential mount bushings, they are probably worn.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 04-30-2003, 06:47 AM
I havent taken one apart yet is that hard to change? Will i need feller guages or does it come out fairly easy and go back in?
Old 06-23-2008, 11:12 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: Changing Ratio
As asked in the previous post, are there any special considerations and adjustments to be made when swapping out the SVX rear diff? In my case a 4.44.
Gene
Gene and Ben
Old 06-23-2008, 12:03 PM
Re: Changing Ratio
to be honest, bring OT's writeup to a shop and have them set the gears up for you... Worth it to have a little piece of mind
Old 06-23-2008, 02:35 PM
bwb3's Avatar
Re: changing ratio
Thanks, I thought someone had a write up somewhere. Is this it? http://www.subaru-svx.net/photos/user.php?svxfiles
Gene
Gene and Ben
Old 06-23-2008, 02:48 PM
Re: changing ratio
Its in my signature.
Old 06-23-2008, 02:55 PM
bwb3's Avatar
Re: changing ratio
I guess I'm not very observant Thanks again.
Gene
Gene and Ben
