rear combination light assembly
I just replaced the seals to hopefully solve a moisture problem in the lenses. It rains here a lot and I don't want to have the lenses fogged up 9 months a year. Anyway, When the assembly was out, I noticed that the bottom seam of the assembly is not real tight. Kind of like the lenses are bowed a bit. Is this common? Is this where the moisture is getting in? Thinking the poor fit it might be caused by using the assembly as a trunk lid handle when the gas struts/stays are blown. That would cause a lot of stress over time.
Re: rear combination light assembly
If you want to make sure that the assembly is sealed, use some black or clear silicone to seal it up. Take the taillight out though, so you can get to all of it and not get silicone all over the car, and just generally do a cleaner, nicer job of it. The little rubber gaskets don't (IMO) work very well after such a long time.
WRT your actual question - you mean the bottom middle of the center tail bar, to the immediate rear of the little lights that light up the license plate? Where the red lens meets the black housing of it? I had one with a similar problem I think, where the lens was sort of pulling away from the housing there in the center. But I didn't try to solve it, just swapped it with another spare that I had, and it never got any water in it. (The left and right ones get water in them a lot though...)
Yep, it is a little separated, mostly in the middle. A new assembly is about $350. Ouch. Might try to seal it up as you recommended of water continues to get in. It is in the garage now though. And dry. Find out tomorrow.
I have been getting water collecting in the deck lid during heavy heavy rains. I just ordered new seals for that center light hopefully that takes care of it.
