#31
Re: Waterpump, Timing belt, replace
Perhaps your timing was off (belt jumped 1 or more teeth)
#32
#33
If I had been half smart instead of half fast (say it out loud) I would have checked that before I removed the belt...
Oh well.... next time...
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
#34
I noticed that I didn't say how I secured the crankshaft when I re-tightened the crank pulley nut.... When I was changing the magneto on my scooter I made a tool for holding the pulley... figured it would work on this too..... I was right...
Here's a picture of the tool.
Mitch Hansen
#35
I copied them onto a DVD... I doubt they would take up much server space.... if someone would like to make them a sticky? I can load them ...somewhere.... just point me
Mitch Hansen
#36
#37
All back together and running... After leaving the SVX sit for damn near a year it's hard to explain the joy of feeling it again... even the loud rear bearing doesn't bother me right now.... Do have an interesting CEL thing going on... It had been coming on intermittently before the timing belt, water pump replacement.... then the first day ...starting the car maybe 20 times... no CEL.... The next day..it came on the 2nd time I started the car and remained on the whole day... starting the car maybe 7 times. Yesterday... no CEL...started the car at least 10 times....
so....my next post will be in the CEL instruction thread..... I'll search a bit harder this time.
Mitch Hansen
#38
Checking codes is super easy. Search, it's been explained in tons of threads, many times over the years.
#39
Ok.... CEL codes 23, Air Flow meter, or Circuit... engine runs very smoothly right now..
code 29 Crank angle sensor (this doesn't sound good) code 34 EGR Solenoid or Circuit hmmm (EGR behind INTAKE MANIFOLD....me not happy) Any suggestions OTHER than a sticky pad over the CEL? Edit: someone should have taken me up on my bet that it was an O2 SENSOR
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . Last edited by Uncamitzi; 09-15-2011 at 12:12 PM. Reason: ADDED THOUGHT |
#40
Allllll righty then..... Cleaned the MAF (special maf spray cleaner... at Reilly 2.68 )
followed the wire to the connector on the Crank angle sensor... wow...wires were cracked touching and pretty much borked. Then pulled all the fuel injector connectors sprayed them with the SPECIAL MAF spray cleaner (Reilly 2.68 ) pulled the MAF connector hosed it down... resprayed the MAF again...really hosed that sucker down.... cleaned the wire mesh ... now it sparkles I'm pretty sure the MAF strip is clean too... Then... I noticed that my head light covers had gone all frosty again... so I polished them up with my rubbing compound BEFORE After: Went for a short drive... Cleared the CEL per the instructions...and now...only have 34 code....EGR valve or circuit... but the car ran GREAT!!!!
Mitch Hansen
#41
Replaced the antenna mast and motor yesterday..(broke it driving though some bushes )
Perhaps that's the end of summer repair on the car. The EGR solenoid / circuit code is still coming on. Not too worried about that... unless someone can tell me that it will be causing problems down the line. after hearing about the many people that have bypassed the EGR valve, I can't imagine it doing much more than sending the CEL light a mention every once in a while... but I'm open to comment. I'm pleased that the car is running so well right now... and I hope that doesn't jinx me Next project ... Car has an intermittent wobble in the front at about 65 MPH... thought it might be an unbalanced wheel...but now I'm thinking suspension... as it wobbles just a bit more when turning right at speed. Comments?
Mitch Hansen
