chek engine-38-
hi, i have a 5 speed transmition in my car. since a do the swap, i have the cel 38
38- Engine torque control Wiring harness between ECU and TCU is in short circuit i have to tap in the wiring to *bypass the tcu? somebody have done this swap? thanks you |
Re: chek engine-38-
Unplug the TCU. You don't have to do anything else.
Re: chek engine-38-
i done that during the swap, but do you know if i have to tap in the ecu a wire to remove the cel? |
Re: chek engine-38-
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
Re: chek engine-38-
ok thanks for the information, im gonna try this! |
Re: chek engine-38-
And this has to be done Y. What if it is not done ? What will happen ? I have to check and see if mine was done.
Re: chek engine-38-
This does not need to be done. It is something leftover from the early days of 5mt swaps that turned out not to be necessary.
Just remove/unplug the TCU (and sell it to some fool with an auto). OP: what year is your car? Must be OBD 1 since the code is a small number like 38. A 96 or 97 cannot have an MT without throwing a CEL with the stock ECU.
Re: chek engine-38-
1904 Svx..... dumb fingers 1994
Re: chek engine-38-
I'll give credit towards a Stage1Av1 for an AWD SVX TCU.
