Old 04-04-2012, 07:19 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Bearing failure or ?
When overtaking a large truck I suddenly detected vibrations I haven't felt before. This was at the bottom of a mountain pass and then there was gravel road and other awful conditions. When we started the downward slope, my breakes started squeeking a bit. I thought maybe they were a bit overheated.
The problem is still around but in low speeds I keep here in town it's not so pronounced. We are visiting my mother who's had Subarus since early 80s and she thinks it's the front bearing. In short, there's a bit of vibration in the steering wheel, in the chairs and some occational squeeking from the left front wheel.
What's your take?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-04-2012, 08:44 AM
dcarrb dcarrb is offline
Re: Bearing failure or ?
Wheel bearing failure usually becomes noticeable as a whine or roaring sound that changes in pitch and volume with variations in speed. As failure progresses, the noise increases. Seems unlikely this is your problem.
Possibly you've warped a brake rotor?
dcb
Old 04-04-2012, 09:13 AM
Old Fogey
It's possible you have a piece of gravel lodged in the LF brake caliper, causing the squeal. I would get the front end in the air, pull the wheels and give the brakes a good look for wear, and grease the slide bolts.
Glenn
Old 04-04-2012, 10:49 AM
kwren's Avatar
kwren kwren is offline
Glenn
Maybe just a CV shaft?
Keith
Old 04-04-2012, 10:50 AM
Wheels tight? Had the car worked on recently?
Old 04-04-2012, 11:23 AM
2nd on the warped rotor....
Old 04-04-2012, 12:13 PM
jetboy's Avatar
Yes, it was subject to a "safety check" a week ago while I had the rallye lights removed. I could always take the wheel on and off. I can probably borrow a torque wrench from my mom's neighbour. How much should I use on the wheels?
As for warped rotor.. why should there be vibration while I'm not braking if the rotor is warped?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
