Old 08-30-2006, 06:02 AM
shotgunslade's Avatar
Clean pic's are tough, especially in this weather. As for $$. I spent $6400 for the car (1994 LSi, Emerald Pearl) two years ago when it had 74,000 miles. Since then, I have spent $12,000 on mods. Why don't you use some of the track shots? Dirt is acceptable in those.
Old 08-30-2006, 06:12 AM
mikecg's Avatar
mikecg mikecg is offline
OK here's my total list:
ECUTune Stage III (You know the list it includes)
K&N Cone Filter on Dayle's inlet B pipe
Motegi MR7 17" rims w/ BFG g-Force T/A KDW-2
Flowmaster Dual-in\Dual-out muffler in a 2 1/2 in manifold back exhaust with 2 High flow Magnaflow cats
Ceramic Brake pads and all 4 corners
Motorsport Warehouse Lowering springs(Factory shocks)
6-speed manual install by you(tom) w/ Clutch Masters FX200, and Momo shift knob
Did a bunch of stereo crap too I just cant remember it all.
Cost:
Purchase: $8000 (in 2003 w/ 20K miles)
Stage III: $5000 (Discounted for being the first)
Wheels and Tires: $1500
6-Speed: $7000 (Something like that)
Old 08-30-2006, 08:29 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Ben,
Timing is everything....I think we (the SVX "cult") have reached critical mass wrt doing "interesting" things to our cars (as Young Tom has acknowledged in his initial post) and SubieSport may....just may....recognize an opportunity to expand their editorial horizons
-Bill
p.s. do we really have to figure out how much we've spent? How about if I just agree that my own labor has no dollar amount this way all the "one off" aspects of BillStock don't add to the bottom line $$
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-30-2006, 08:36 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
ok a buddy of mine has agreed to take some digital SLR photos of my car/engine bay next week. Ill get stuff together.
phil
Modifications
Drivetrain:
4.11 5mt conversion. MY03 parts
RPS 405ft/lb street/strip full-faced clutch
legacy 19lb flywheel
STi trans mount
Kumho Ecsta MX 225/50yr16
Engine:
replaced with 41k mile stock internal EG33
a/c delete
T3/t04E-60 trim turbocharger, .60a/r coldside |.63 a/r hotside
Custom 304L stainless collector (3-2-1)
Custom 3" 304L turbo back exhaust system-fully mendral
26"x6.5"x3" Front Mount intercooler, 25" endtanks
Custom 2.5" 304L Stainless mendral intercooler piping
Custom 3" to duel 2.5" intake plenum adapter
Tial 38mm External Dump wastegate- "big" yellow spring(10.1psi)
HKS Super Sequential blowoff valve
HKS Super Mega Flow 80mm air filter
Electronics and Management:
ECUtune Stage 2v6 engine management system (on the fly switchable pump93 and E85 Ethanol maps)
Z32 300zx Mass air flow sensor conversion(ecutune)/tomei harness
Vortech Rising Rate Fuel Pressure Regulator(boost dependent, 8:1)
AEM guage type Wideband EUGO controller(in lambda )
Autometer vac/boost guage(20psi)
other mods:
Carbon fiber hood w/hoodscoop
JDM SVX Hood emblem
740IL HID projector/bulb/ballest conversion
JDM "Boxer" engine cover
JDM fusebox cover
stripped trunk
Pioneer MP3 Headunit
~Phil
Old 08-30-2006, 08:59 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally Posted by SVXRide
Ben,
I know exactly what we spent. $2005.99
Old 08-30-2006, 09:32 AM
Bill, yes I need you to give me a rough estimate of mods... and your initial price much like Mikecg but it doesn't have to be such a comprehensive list.
Phil, I need a price from you as well!!
Old 08-30-2006, 01:28 PM
SVXRide's Avatar
Tom,
$4k for the original purchase, less than that in total mods
-Bill
Old 08-30-2006, 01:46 PM
Tom,
-Bill
Bullcrap!! I can think of over 4k in work you ave done to your car... not to mention the stuff that is "secret"...hahaha... give me a more realistic figure
Old 08-30-2006, 02:24 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Tom I think we can put my grand total at $11,000 with Vehicle purchase.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 08-30-2006, 02:29 PM
just do me a favor and break it down like Mikecg and Shotgunslade did please
Old 08-30-2006, 02:52 PM
gest24's Avatar
#1 6MT In Cali
Didn't you get my PM? I had a parts breakdown in there I think.
But Here we go:
Car: $4400
Rims/Tires: $850
Intake: $150
Exhaust: $900
Stage 2v5/Z32 MAF: $650
Rotors: $150
Pads: $150
S/S Lines: $100
WRX Steering Wheel: $50
STi Shifter Trim: $80
STi 6MT Swap: $4900
Tom's Fee: $1800
Fluids for Swap: $250
I think thats everything.
RIP
84 VW Scirocco
02 WRX
Old 08-30-2006, 06:22 PM
OK. I'll wash it and wax it this weekend. But the rotors will still look like crap, and I don't know if we're going to have any sun for photography.
Old 08-30-2006, 06:29 PM
gest24's Avatar
#1 6MT In Cali
Round one of the "Fancy" pictures are on my Homepage under Subies 2.
RIP
84 VW Scirocco
02 WRX
Old 08-30-2006, 08:32 PM
I am looking to round up information and high resolution photos of the following cars...
Completely Stock... Cars needs to be VERY clean and stock down to the wheels and tire size... yes, that means NO modifications
Modified Auto- Preferable a highly modified auto like SVXride would fit perfectly
Modified 5mt- Shotgunslade, your car fits very nicely right here
Modified 6mt- Kerry I would say that this is for you but you already made your subscription so I would say Subafreak's would be about right for this spot
Phil, your turbo is an outstanding example of excellence for the Custom FI category. I need some pics that are your most outstanding quality.
Mikecg I need some pic's of your car along with any info I might not know about it.
I will also submitt my own vehicle along with Mike's as a flagship for LAN's ECUtune business as I am completely pleased with everything his products have done for me and my vehicle
Ben and Dave. A good writeup on your racer and how you have been fairing this season would be awsome as well.
I need particulars on your vehicles and GOOD pictures... I mean REALLY good pics. I also need details on who has done your work and what EXACTLY has been done... Well feed em to me
Do you think my Claret would be concidered modified, Young Tom?
I noticed you did not mention me.
Old 08-30-2006, 10:14 PM
Tom, you would be under the highly modified auto category and yes, I would love to have an entrance of your car
